gz/rendering/RenderEngineManager.hh
17 #ifndef GZ_RENDERING_RENDERENGINEMANAGER_HH_
18 #define GZ_RENDERING_RENDERENGINEMANAGER_HH_
20 #include <list>
21 #include <map>
22 #include <memory>
23 #include <string>
24 #include <vector>
25 #include <gz/common/SingletonT.hh>
26 #include <gz/common/SuppressWarning.hh>
27 #include "gz/rendering/config.hh"
28 #include "gz/rendering/Export.hh"
29
30 namespace ignition
31 {
32  namespace rendering
33  {
34  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
35  //
36  // forward declarations.
37  class RenderEngine;
38  class RenderEngineManagerPrivate;
39
46  class IGNITION_RENDERING_VISIBLE RenderEngineManager :
47  public virtual common::SingletonT<RenderEngineManager>
48  {
51
54
57  public: unsigned int EngineCount() const;
58
63  public: bool HasEngine(const std::string &_name) const;
64
69  public: bool IsEngineLoaded(const std::string &_name) const;
70
74
82  public: RenderEngine *Engine(const std::string &_name,
83  const std::map<std::string, std::string> &_params = {},
84  const std::string &_path = "");
85
92  public: RenderEngine *EngineAt(unsigned int _index,
93  const std::map<std::string, std::string> &_params = {},
94  const std::string &_path = "");
95
101  public: bool UnloadEngine(const std::string &_name);
102
108  public: bool UnloadEngineAt(unsigned int _index);
109
115  public: void RegisterEngine(const std::string &_name,
116  RenderEngine *_engine);
117
122  public: void UnregisterEngine(const std::string &_name);
123
127  public: void UnregisterEngine(RenderEngine *_engine);
128
132  public: void UnregisterEngineAt(unsigned int _index);
133
136  public: void SetPluginPaths(const std::list<std::string> &_paths);
137
142
144  private: friend class gz::common::SingletonT<RenderEngineManager>;
145  };
146  }
147  }
148 }
149 #endif
Collection of render-engines. This provides access to all the render-engines available at runtime....
Definition: gz/rendering/RenderEngineManager.hh:48
Unload the render-engine at the given index. If the no render-engine is registered under the given na...
Unregister the given render-engine. If the given render-engine is not currently registered,...
Unload the render-engine with the given name. If the no render-engine is registered under the given n...
RenderEngine * Engine(const std::string &_name, const std::map< std::string, std::string > &_params={}, const std::string &_path="")
Get the render-engine with the given name. If the no render-engine is registered under the given name...
Determine if a render-engine with the given name is already loaded.
Unregister a render-engine registered under the given name. If no render-engine is registered under t...
std::vector< std::string > LoadedEngines() const
Get the list of all engines already loaded.
void RegisterEngine(const std::string &_name, RenderEngine *_engine)
Register a new render-engine under the given name. If the given name is already in use,...
Determine if a render-engine with the given name is avaiable. It also checks the list of default engi...
RenderEngine * EngineAt(unsigned int _index, const std::map< std::string, std::string > &_params={}, const std::string &_path="")
Get the render-engine at the given index. If no render-engine is exists at the given index,...
void SetPluginPaths(const std::list< std::string > &_paths)
Set the plugin paths from which render engines can be loaded.
Unregister a render-engine at the given index. If the no render-engine is registered at the given ind...
Get the number of available render-engines.
Definition: gz/rendering/RenderEngine.hh:37
