gz/rendering/base/BaseRenderEngine.hh
17 #ifndef GZ_RENDERING_BASE_BASERENDERENGINE_HH_
18 #define GZ_RENDERING_BASE_BASERENDERENGINE_HH_
20 #include <map>
21 #include <string>
22 #include <vector>
23 #include <gz/common/SuppressWarning.hh>
25 #include "gz/rendering/Storage.hh"
26
27 namespace ignition
28 {
29  namespace rendering
30  {
31  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
32  //
33  class IGNITION_RENDERING_VISIBLE BaseRenderEngine :
34  public virtual RenderEngine
35  {
36  protected: BaseRenderEngine();
37
38  public: virtual ~BaseRenderEngine();
39
40  // Documentation Inherited.
41  public: virtual bool Load(
42  const std::map<std::string, std::string> &_params = {}) override;
43
44  public: virtual bool Init() override;
45
46  public: virtual bool Fini() override;
47
48  public: virtual bool IsLoaded() const override;
49
50  public: virtual bool IsInitialized() const override;
51
52  public: virtual bool IsEnabled() const override;
53
54  public: virtual unsigned int SceneCount() const override;
55
56  public: virtual bool HasScene(ConstScenePtr _scene) const override;
57
58  public: virtual bool HasSceneId(unsigned int _id) const override;
59
60  public: virtual bool HasSceneName(const std::string &_name) const
61  override;
62
63  public: virtual ScenePtr SceneById(unsigned int _id) const override;
64
65  public: virtual ScenePtr SceneByName(const std::string &_name) const
66  override;
67
68  public: virtual ScenePtr SceneByIndex(unsigned int _index) const override;
69
70  public: virtual void DestroyScene(ScenePtr _scene) override;
71
72  public: virtual void DestroySceneById(unsigned int _id) override;
73
74  public: virtual void DestroySceneByName(const std::string &_name)
75  override;
76
77  public: virtual void DestroySceneByIndex(unsigned int _index) override;
78
79  public: virtual void DestroyScenes() override;
80
81  public: virtual ScenePtr CreateScene(const std::string &_name) override;
82
83  public: virtual ScenePtr CreateScene(unsigned int _id,
84  const std::string &_name) override;
85
86  public: virtual void Destroy() override;
87
88  // Documentation Inherited
89  public: virtual void AddResourcePath(const std::string &_path) override;
90
91  // Documentation Inherited
92  public: virtual void SetHeadless(bool _headless) override;
93
94  // Documentation Inherited
95  public: virtual bool Headless() const override;
96
97  // Documentation Inherited
98  public: virtual RenderPassSystemPtr RenderPassSystem() const override;
99
100  protected: virtual void PrepareScene(ScenePtr _scene);
101
102  protected: virtual unsigned int NextSceneId();
103
106  protected: virtual bool LoadImpl(
107  const std::map<std::string, std::string> &_params) = 0;
108
109  protected: virtual bool InitImpl() = 0;
110
111  protected: virtual ScenePtr CreateSceneImpl(unsigned int _id,
112  const std::string &_name) = 0;
113
114  protected: virtual SceneStorePtr Scenes() const = 0;
115
116  protected: bool loaded = false;
117
118  protected: bool initialized = false;
119
120  protected: bool isHeadless = false;
121
123  protected: std::string winID = "";
124
125  protected: unsigned int nextSceneId;
126
131
135  };
136  }
137  }
138 }
139 #endif
Definition: gz/rendering/base/BaseRenderEngine.hh:35
Destroy the scene at the given index. If no scenes exist at the given index, no work will be done.
Add path to media resource location.
Determines if the render-engine has been initialized.
Get the number of scenes actively managed by this render-engine.
RenderPassSystemPtr renderPassSystem
Render pass system for this render engine.
Definition: gz/rendering/base/BaseRenderEngine.hh:133
virtual ScenePtr CreateScene(unsigned int _id, const std::string &_name) override
Create a new scene with the given ID. The given ID should be unique across all scenes managed by this...
virtual bool LoadImpl(const std::map< std::string, std::string > &_params)=0
Engine implementation of Load function.
std::vector< std::string > resourcePaths
a list of paths that render engines use to locate their resources
Definition: gz/rendering/base/BaseRenderEngine.hh:130
Determines if the render-engine can be used. Despite loading and initializing the render-engine,...
Definition: gz/rendering/base/BaseRenderEngine.hh:125
Get the scene at the given index. If no scenes exist at the given index, NULL will be returned.
Determines if the render-engine has been loaded.
Get headless mode.
Destroy the given scene. If the given scene is not managed by this render-engine, no work will be don...
Determine if the given scene is actively managed by this render-engine.
virtual void DestroySceneByName(const std::string &_name) override
Destroy the scene with the given name. If no scenes exist with the given name, no work will be done.
Destroy the scene with the given ID. If no scenes exist with the given ID, no work will be done.
virtual bool HasSceneName(const std::string &_name) const override
Determine if this render-engine manages a scene with the given name.
Get the render pass system for this engine.
Destroys all scenes created by render-engine and releases all loaded resources. This should be called...
Create a new scene with the given name. The given name should be unique across all scenes managed by ...
virtual ScenePtr CreateSceneImpl(unsigned int _id, const std::string &_name)=0
virtual SceneStorePtr Scenes() const =0
Determine if this render-engine manages a scene with the given ID.
Get the scene with the given ID. If no scenes exist with the given ID, NULL will be returned.
virtual bool Load(const std::map< std::string, std::string > &_params={}) override
Load any necessary resources to set up render-engine. This should called before any other function.
Initialize the render-engine. This should be called immediately after a successful call to Load.
Destroy all scenes managed by this render-engine.
virtual ScenePtr SceneByName(const std::string &_name) const override
Get the scene with the given name. If no scenes exist with the given name, NULL will be returned.
Set headless mode Only available in OGRE 2.2, which makes use of EGL.
Definition: gz/rendering/RenderEngine.hh:37
