gz/rendering/ogre2/Ogre2GpuRays.hh
16 */
17
18 #ifndef GZ_RENDERING_OGRE2_OGRE2GPURAYS_HH_
19 #define GZ_RENDERING_OGRE2_OGRE2GPURAYS_HH_
20
21 #include <string>
22 #include <memory>
23
26 #include "gz/rendering/ogre2/Export.hh"
31
32 #include "gz/common/Event.hh"
33 #include "gz/common/Console.hh"
34
35 namespace Ogre
36 {
37  class Material;
38  class RenderTarget;
39  class Texture;
40  class Viewport;
41 }
42
43 namespace ignition
44 {
45  namespace rendering
46  {
47  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
48  //
49  // Forward declaration
50  class Ogre2GpuRaysPrivate;
51
65  class IGNITION_RENDERING_OGRE2_VISIBLE Ogre2GpuRays :
66  public BaseGpuRays<Ogre2Sensor>
67  {
69  protected: Ogre2GpuRays();
70
72  public: virtual ~Ogre2GpuRays();
73
74  // Documentation inherited
75  public: virtual void Init() override;
76
77  // Documentation inherited
78  public: virtual void Destroy() override;
79
81  public: virtual void CreateRenderTexture();
82
83  // Documentation inherited
84  public: virtual void PreRender() override;
85
86  // Documentation inherited
87  public: virtual void PostRender() override;
88
89  // Documentation inherited
90  public: virtual const float *Data() const override;
91
92  // Documentation inherited.
93  public: virtual void Copy(float *_data) override;
94
95  // Documentation inherited.
97  std::function<void(const float *_frame, unsigned int _width,
98  unsigned int _height, unsigned int _channels,
99  const std::string &_format)> _subscriber) override;
100
101  // Documentation inherited.
102  public: virtual RenderTargetPtr RenderTarget() const override;
103
108  private: virtual void Set1stTextureSize(const unsigned int _w,
109  const unsigned int _h = 1);
110
115  private: virtual void SetRangeCount(const unsigned int _w,
116  const unsigned int _h = 1);
117
118  // Documentation inherited.
119  private: virtual void Render() override;
120
122  private: void ConfigureCamera();
123
125  private: void CreateCamera();
126
128  private: virtual void CreateGpuRaysTextures();
129
131  private: void UpdateRenderTarget1stPass();
132
134  private: void UpdateRenderTarget2ndPass();
135
138  private: void CreateSampleTexture();
139
141  private: void Setup1stPass();
142
144  private: void Setup2ndPass();
145
151  private: math::Vector2d SampleCubemap(const math::Vector3d &_v,
152  unsigned int &_faceIndex);
153
156  private: std::unique_ptr<Ogre2GpuRaysPrivate> dataPtr;
157
159  private: friend class Ogre2Scene;
160  };
161  }
162  }
163 }
164 #endif
Definition: gz/rendering/base/BaseGpuRays.hh:46
Gpu Rays used to render range data into an image buffer The ogre2 implementation takes a 2 pass proce...
Definition: gz/rendering/ogre2/Ogre2GpuRays.hh:67
virtual common::ConnectionPtr ConnectNewGpuRaysFrame(std::function< void(const float *_frame, unsigned int _width, unsigned int _height, unsigned int _channels, const std::string &_format)> _subscriber) override
Pointer to the render target.
Copy to the specified memory direction the gpu rays data.
Preforms any necessary final rendering work. Once rendering is complete the camera will alert any lis...
virtual const float * Data() const override
All things needed to get back z buffer for gpu rays data.
Create dummy render texture. Needed to satisfy inheritance.
Ogre2.x implementation of the scene class.
Definition: gz/rendering/ogre2/Ogre2Scene.hh:59
