gz/rendering/ogre2/Ogre2LidarVisual.hh
16 */
17
18 #ifndef IGNITION_RENDERING_OGRE2_OGRELIDARVISUAL_HH_
19 #define IGNITION_RENDERING_OGRE2_OGRELIDARVISUAL_HH_
20
21 #include <memory>
22 #include <vector>
26
27 namespace ignition
28 {
29  namespace rendering
30  {
31  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
32  //
33  // Forward declaration
34  class Ogre2LidarVisualPrivate;
35
37  class IGNITION_RENDERING_OGRE2_VISIBLE Ogre2LidarVisual
38  : public BaseLidarVisual<Ogre2Visual>
39  {
41  protected: Ogre2LidarVisual();
42
44  public: virtual ~Ogre2LidarVisual();
45
46  // Documentation inherited.
47  public: virtual void Init() override;
48
49  // Documentation inherited.
50  public: virtual void PreRender() override;
51
52  // Documentation inherited.
53  public: virtual void Destroy() override;
54
55  // Documentation inherited
56  public: virtual void Update() override;
57
58  // Documentation inherited
59  public: virtual void SetPoints(
60  const std::vector<double> &_points) override;
61
62  // Documentation inherited
63  public: virtual void ClearPoints() override;
64
65  // Documentation inherited
66  public: virtual unsigned int PointCount() const override;
67
68  // Documentation inherited
69  public: virtual std::vector<double> Points() const override;
70
72  private: void Create();
73
75  private: void ClearVisualData();
76
77  // Documentation inherited
78  public: virtual void SetVisible(bool _visible) override;
79
81  private: friend class Ogre2Scene;
82
85  };
86  }
87  }
88 }
89 #endif
Base implementation of a Lidar Visual.
Definition: gz/rendering/base/BaseLidarVisual.hh:37
Ogre 2.x implementation of a Lidar Visual.
Definition: gz/rendering/ogre2/Ogre2LidarVisual.hh:39
Update the Visual.
virtual std::vector< double > Points() const override
Get the points in laser data.
virtual void SetPoints(const std::vector< double > &_points) override
Set lidar points to be visualised.
Clear the points of the lidar visual.
Initialize the visual.
Get number of points in laser data.
Ogre2.x implementation of the scene class.
Definition: gz/rendering/ogre2/Ogre2Scene.hh:59
