gz/rendering/ogre2/Ogre2Mesh.hh
17 #ifndef GZ_RENDERING_OGRE2_OGRE2MESH_HH_
18 #define GZ_RENDERING_OGRE2_OGRE2MESH_HH_
20 #include <map>
21 #include <memory>
22 #include <string>
23 #include <unordered_map>
24 #include <vector>
29
30 namespace Ogre
31 {
32  class Item;
33  class SubItem;
34 }
35
36 namespace ignition
37 {
38  namespace rendering
39  {
40  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
41  //
42  // forward declaration
43  class Ogre2MeshPrivate;
44  class Ogre2SubMeshPrivate;
45
47  class IGNITION_RENDERING_OGRE2_VISIBLE Ogre2Mesh :
48  public BaseMesh<Ogre2Geometry>
49  {
51  protected: Ogre2Mesh();
52
54  public: virtual ~Ogre2Mesh();
55
56  // Documentation inherited
57  public: virtual void Destroy() override;
58
59  // Documentation inherited.
60  public: virtual bool HasSkeleton() const override;
61
62  // Documentation inherited.
64  SkeletonLocalTransforms() const override;
65
66  // Documentation inherited.
67  public: virtual void SetSkeletonLocalTransforms(
68  const std::map<std::string, math::Matrix4d> &_tfs) override;
69
70  // Documentation inherited.
72  SkeletonWeights() const override;
73
74  // Documentation inherited.
75  public: virtual void SetSkeletonWeights(
76  const std::unordered_map<std::string, float> &_weights) override;
77
78  // Documentation inherited.
79  public: virtual void SetSkeletonAnimationEnabled(const std::string &_name,
80  bool _enabled, bool _loop = true, float _weight = 1.0) override;
81
82  // Documentation inherited.
83  public: virtual bool SkeletonAnimationEnabled(const std::string &_name)
84  const override;
85
86  // Documentation inherited.
87  public: virtual void UpdateSkeletonAnimation(
88  std::chrono::steady_clock::duration _time) override;
89
90  // Documentation inherited
91  public: virtual Ogre::MovableObject *OgreObject() const override;
92
94  protected: virtual SubMeshStorePtr SubMeshes() const override;
95
98
100  protected: Ogre::Item *ogreItem = nullptr;
101
103  private: friend class Ogre2Scene;
104
106  private: friend class Ogre2MeshFactory;
107
109  private: std::unique_ptr<Ogre2MeshPrivate> dataPtr;
110  };
111
113  class IGNITION_RENDERING_OGRE2_VISIBLE Ogre2SubMesh :
114  public BaseSubMesh<Ogre2Object>
115  {
117  protected: Ogre2SubMesh();
118
120  public: virtual ~Ogre2SubMesh();
121
122  // Documentation inherited
123  public: virtual void Destroy() override;
124
127  public: void SetMeshName(const std::string &_name);
128
130  public: virtual Ogre::SubItem *Ogre2SubItem() const;
131
134  protected: virtual void SetMaterialImpl(MaterialPtr _material) override;
135
137  protected: virtual void Init() override;
138
140  protected: Ogre::SubItem *ogreSubItem = nullptr;
141
143  private: friend class Ogre2Scene;
144
147  private: friend class Ogre2SubMeshStoreFactory;
148
150  private: std::unique_ptr<Ogre2SubMeshPrivate> dataPtr;
151  };
152  }
153  }
154 }
155 #endif
Definition: gz/rendering/base/BaseMesh.hh:39
Definition: gz/rendering/base/BaseMesh.hh:133
Ogre2.x implementation of the mesh factory class.
Definition: gz/rendering/ogre2/Ogre2MeshFactory.hh:47
Ogre2.x implementation of the mesh class.
Definition: gz/rendering/ogre2/Ogre2Mesh.hh:49
virtual Ogre::MovableObject * OgreObject() const override
Get the ogre object representing this geometry.
virtual std::unordered_map< std::string, float > SkeletonWeights() const override
Get skeleton node weight.
Check whether the mesh has skeleton.
virtual void SetSkeletonLocalTransforms(const std::map< std::string, math::Matrix4d > &_tfs) override
Set transforms for the skeleton.
Get a list of submeshes in this mesh.
virtual bool SkeletonAnimationEnabled(const std::string &_name) const override
Get whether a skeleton animation is enabled or not.
Ogre2SubMeshStorePtr subMeshes
Store containing all the submeshes.
Definition: gz/rendering/ogre2/Ogre2Mesh.hh:97
virtual void SetSkeletonWeights(const std::unordered_map< std::string, float > &_weights) override
Set skeleton node weight.
virtual std::map< std::string, math::Matrix4d > SkeletonLocalTransforms() const override
Get the skeleton local transforms.
virtual void SetSkeletonAnimationEnabled(const std::string &_name, bool _enabled, bool _loop=true, float _weight=1.0) override
Set whether a skeleton animation should be enabled or not.
virtual void UpdateSkeletonAnimation(std::chrono::steady_clock::duration _time) override
Play the active skeleton animation to the specified time.
Ogre2.x implementation of the scene class.
Definition: gz/rendering/ogre2/Ogre2Scene.hh:59
Ogre2.x implementation of a submesh store factory class.
Definition: gz/rendering/ogre2/Ogre2MeshFactory.hh:106
Ogre2.x implementation of the submesh class.
Definition: gz/rendering/ogre2/Ogre2Mesh.hh:115
virtual Ogre::SubItem * Ogre2SubItem() const
Get internal ogre subitem created from this submesh.
Helper function for setting the material to use.
Set the name of the mesh stored in Ogre2.
Initialize the submesh.
