gz/rendering/ogre2/Ogre2RenderEngine.hh
17 #ifndef GZ_RENDERING_OGRE2_OGRE2RENDERENGINE_HH_
18 #define GZ_RENDERING_OGRE2_OGRE2RENDERENGINE_HH_
20 #include <map>
21 #include <memory>
22 #include <string>
23 #include <vector>
24
25 #include <gz/common/SingletonT.hh>
26
32 #include "gz/rendering/ogre2/Export.hh"
33
34 namespace Ogre
35 {
36  class LogManager;
37  class Root;
38  class Window;
39  namespace v1
40  {
41  class OverlaySystem;
42  }
43
44  class HlmsPbsTerraShadows;
45  class CompositorWorkspaceListener;
46 }
47
48 namespace ignition
49 {
50  namespace rendering
51  {
52  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
53  //
54  // forward declaration
55  class Ogre2RenderEnginePrivate;
56  class Ogre2IgnHlmsCustomizations;
57
59  class IGNITION_RENDERING_OGRE2_VISIBLE Ogre2RenderEnginePlugin :
60  public RenderEnginePlugin
61  {
64
66  public: ~Ogre2RenderEnginePlugin() = default;
67
70  public: std::string Name() const;
71
74  public: RenderEngine *Engine() const;
75  };
76
80  class IGNITION_RENDERING_OGRE2_VISIBLE Ogre2RenderEngine :
81  public virtual BaseRenderEngine,
82  public common::SingletonT<Ogre2RenderEngine>
83  {
85  private: Ogre2RenderEngine();
86
88  public: virtual ~Ogre2RenderEngine();
89
90  // Documentation Inherited.
91  public: virtual void Destroy() override;
92
93  // Documentation Inherited.
94  public: virtual bool IsEnabled() const override;
95
96  // Documentation Inherited.
97  public: virtual std::string Name() const override;
98
101  public: void AddResourcePath(const std::string &_uri) override;
102
104  public: Ogre::Window * OgreWindow() const;
105
108  public: virtual Ogre::Root *OgreRoot() const;
109
119  const unsigned int _width, const unsigned int _height,
120  const double _ratio, const unsigned int _antiAliasing);
121
127
131  protected: virtual ScenePtr CreateSceneImpl(unsigned int _id,
132  const std::string &_name) override;
133
137  protected: virtual SceneStorePtr Scenes() const override;
138
139  // Documentation Inherited.
140  protected: virtual bool LoadImpl(
141  const std::map<std::string, std::string> &_params) override;
142
145  protected: virtual bool InitImpl() override;
146
148  private: void LoadAttempt();
149
151  private: void CreateLogger();
152
154  private: void CreateContext();
155
157  private: void RegisterHlms();
158
160  private: void CreateRoot();
161
163  private: void CreateOverlay();
164
166  private: void LoadPlugins();
167
169  private: void CreateRenderSystem();
170
172  private: void CreateRenderWindow();
173
175  private: void CreateResources();
176
178  private: void InitAttempt();
179
183
186  public: Ogre2IgnHlmsCustomizations &HlmsCustomizations();
187
191  public: Ogre::v1::OverlaySystem *OverlaySystem() const;
192
199  public: Ogre::HlmsPbsTerraShadows *HlmsPbsTerraShadows() const;
200
209  public: Ogre::CompositorWorkspaceListener
211
213  private: Ogre::v1::OverlaySystem *ogreOverlaySystem = nullptr;
214
216  private: Ogre2SceneStorePtr scenes;
217
219  private: Ogre::Root *ogreRoot = nullptr;
220
222  private: Ogre::LogManager *ogreLogManager = nullptr;
223
225  private: std::vector<std::string> ogrePaths;
226
228  private: void *dummyDisplay = nullptr;
229
231  private: void *dummyContext = nullptr;
232
234  private: uint64_t dummyWindowId = 0u;
235
237  private: Ogre::Window *window = nullptr;
238
240  private: bool useCurrentGLContext = false;
241
244
246  private: friend class common::SingletonT<Ogre2RenderEngine>;
247  };
248  }
249  }
250 }
251 #endif
Definition: gz/rendering/base/BaseRenderEngine.hh:35
Plugin for loading ogre render engine.
Definition: gz/rendering/ogre2/Ogre2RenderEngine.hh:61
Get the name of the render engine loaded by this plugin.
RenderEngine * Engine() const
Get a pointer to the render engine loaded by this plugin.
Ogre2 render engine class. A singleton class that manages the underlying ogre2 render engine,...
Definition: gz/rendering/ogre2/Ogre2RenderEngine.hh:83
Ogre::v1::OverlaySystem * OverlaySystem() const
virtual Ogre::Root * OgreRoot() const
Get the ogre2 root object.
Get a pointer to the list of scenes managed by the render engine.
Ogre::CompositorWorkspaceListener * TerraWorkspaceListener() const
Determines if the render-engine can be used. Despite loading and initializing the render-engine,...
Initialize the render engine.
Get name of the render-engine.
Ogre::HlmsPbsTerraShadows * HlmsPbsTerraShadows() const
rendering::GraphicsAPI GraphicsAPI() const
Get the render engine's graphics API Note: Do not merge this forward. This has been changed to virtua...
std::vector< unsigned int > FSAALevels() const
Get a list of all supported FSAA levels for this render system.
Destroys all scenes created by render-engine and releases all loaded resources. This should be called...
virtual bool LoadImpl(const std::map< std::string, std::string > &_params) override
Engine implementation of Load function.
std::string CreateRenderWindow(const std::string &_handle, const unsigned int _width, const unsigned int _height, const double _ratio, const unsigned int _antiAliasing)
Create a render window.
Add path to resource in ogre2's resource manager.
virtual ScenePtr CreateSceneImpl(unsigned int _id, const std::string &_name) override
Create a scene.
Ogre2IgnHlmsCustomizations & HlmsCustomizations()
Retrieves Hlms customizations for tweaking them.
return the ogre window
Base plugin class for render engines.
Definition: gz/rendering/RenderEnginePlugin.hh:41
Definition: gz/rendering/RenderEngine.hh:37
GraphicsAPI
The graphics API used by the render engine.
Definition: gz/rendering/GraphicsAPI.hh:33
