gz/rendering/ogre2/Ogre2ThermalCamera.hh
16 */
17
18 #ifndef GZ_RENDERING_OGRE2_OGRE2THERMALCAMERA_HH_
19 #define GZ_RENDERING_OGRE2_OGRE2THERMALCAMERA_HH_
20
21 #ifdef _WIN32
22  // Ensure that Winsock2.h is included before Windows.h, which can get
23  // pulled in by anybody (e.g., Boost).
24  #include <Winsock2.h>
25 #endif
26
27 #include <memory>
28 #include <string>
29
31 #include "gz/rendering/ogre2/Export.hh"
33
34 #include "gz/common/Event.hh"
35 #include "gz/common/Console.hh"
36
37 namespace Ogre
38 {
39  class Material;
40  class RenderTarget;
41  class Texture;
42  class Viewport;
43 }
44
45 namespace ignition
46 {
47  namespace rendering
48  {
49  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
50  //
51  // Forward declaration
52  class Ogre2ThermalCameraPrivate;
53
55  class IGNITION_RENDERING_OGRE2_VISIBLE Ogre2ThermalCamera :
56  public BaseThermalCamera<Ogre2Sensor>
57  {
59  protected: Ogre2ThermalCamera();
60
62  public: virtual ~Ogre2ThermalCamera();
63
65  public: virtual void Init() override;
66
67  // Documentation inherited
68  public: virtual void Destroy() override;
69
70  // Documentation inherited
71  public: virtual void PreRender() override;
72
74  public: virtual void PostRender() override;
75
79  public: virtual gz::common::ConnectionPtr ConnectNewThermalFrame(
80  std::function<void(const uint16_t *, unsigned int, unsigned int,
81  unsigned int, const std::string &)> _subscriber) override;
82
84  public: virtual void Render() override;
85
88  protected: virtual RenderTargetPtr RenderTarget() const override;
89
91  protected: void CreateCamera();
92
94  protected: virtual void CreateRenderTexture();
95
97  protected: virtual void CreateThermalTexture();
98
100  protected: Ogre::Camera *ogreCamera = nullptr;
101
105
106  private: friend class Ogre2Scene;
107  };
108  }
109  }
110 }
111 #endif
Base implementation of the ThermalCamera class.
Definition: gz/rendering/base/BaseThermalCamera.hh:37
Ogre2.x implementation of the scene class.
Definition: gz/rendering/ogre2/Ogre2Scene.hh:59
Thermal camera used to render thermal data into an image buffer.
Definition: gz/rendering/ogre2/Ogre2ThermalCamera.hh:57
Get a pointer to the render target.
Render the camera.
Create thermal texture.
void CreateCamera()
Create the camera.
Initialize the camera.
Implementation of the render call.
Create dummy render texture. Needed to satisfy inheritance.
virtual gz::common::ConnectionPtr ConnectNewThermalFrame(std::function< void(const uint16_t *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
Connect to the new thermal image event.
