Camera.hh
17 #ifndef GZ_RENDERING_CAMERA_HH_
18 #define GZ_RENDERING_CAMERA_HH_
20 #include <string>
21
22 #include <gz/common/Event.hh>
23 #include <gz/math/Matrix4.hh>
24
25 #include "gz/rendering/config.hh"
26 #include "gz/rendering/Image.hh"
29 #include "gz/rendering/Sensor.hh"
30 #include "gz/rendering/Scene.hh"
31
32 // overloaded-virtuals warnings appeared on Ubuntu Noble
33 // GCC-13. it is not easy to fix them without breaking ABI
34 // ignore them to preserve current ABI.
35 #if defined(__GNUC__) || defined(__clang__)
36 # pragma GCC diagnostic push
37 # pragma GCC diagnostic ignored "-Woverloaded-virtual"
38 #endif
39
40 namespace gz
41 {
42  namespace rendering
43  {
44  inline namespace GZ_RENDERING_VERSION_NAMESPACE {
45  //
47  enum GZ_RENDERING_VISIBLE CameraProjectionType
48  {
53  };
54
57  class GZ_RENDERING_VISIBLE Camera :
58  public virtual Sensor
59  {
61  public: typedef std::function<void(const void*, unsigned int,
62  unsigned int, unsigned int, const std::string&)> NewFrameListener;
63
65  public: virtual ~Camera();
66
69  public: virtual unsigned int ImageWidth() const = 0;
70
73  public: virtual void SetImageWidth(unsigned int _width) = 0;
74
77  public: virtual unsigned int ImageHeight() const = 0;
78
81  public: virtual void SetImageHeight(unsigned int _height) = 0;
82
86  public: virtual PixelFormat ImageFormat() const = 0;
87
91  public: virtual void SetImageFormat(PixelFormat _format,
92  bool _reinterpretable = false) = 0;
93
96  public: virtual unsigned int ImageMemorySize() const = 0;
97
100  public: virtual math::Angle HFOV() const = 0;
101
104  public: virtual void SetHFOV(const math::Angle &_hfov) = 0;
105
113  public: virtual double AspectRatio() const = 0;
114
123  public: virtual void SetAspectRatio(const double _ratio) = 0;
124
125  // TODO(anyone): add auto-aspect ratio
126
129  public: virtual unsigned int AntiAliasing() const = 0;
130
136  public: virtual void SetAntiAliasing(const unsigned int _aa) = 0;
137
140  public: virtual double FarClipPlane() const = 0;
141
144  public: virtual void SetFarClipPlane(const double _far) = 0;
145
148  public: virtual double NearClipPlane() const = 0;
149
152  public: virtual void SetNearClipPlane(const double _near) = 0;
153
157  public: virtual void Render() = 0;
158
163  public: virtual void PostRender() = 0;
164
167  // \return visual for that position, null if no visual was found
168  public: virtual VisualPtr VisualAt(const gz::math::Vector2i
169  &_mousePos) = 0;
170
176  public: virtual void Update() = 0;
177
183  public: virtual Image CreateImage() const = 0;
184
191  public: virtual void Capture(Image &_image) = 0;
192
198  public: virtual void Copy(Image &_image) const = 0;
199
210  public: bool CopyTo(const PixelBuffer &_buffer) const;
211
217  public: virtual bool SaveFrame(const std::string &_name) = 0;
218
222  NewFrameListener _listener) = 0;
223
226  public: virtual RenderWindowPtr CreateRenderWindow() = 0;
227
230  public: virtual math::Matrix4d ProjectionMatrix() const = 0;
231
234  public: virtual math::Matrix4d ViewMatrix() const = 0;
235
239  public: virtual void SetProjectionMatrix(const math::Matrix4d &_matrix)
240  = 0;
241
244  public: virtual CameraProjectionType ProjectionType() const = 0;
245
254  public: virtual void SetProjectionType(CameraProjectionType _type) = 0;
255
259  public: virtual math::Vector2i Project(const math::Vector3d &_pt) const
260  = 0;
261
274  public: virtual void SetTrackTarget(const NodePtr &_target,
275  const math::Vector3d &_offset = math::Vector3d::Zero,
276  const bool _worldFrame = false) = 0;
277
280  public: virtual NodePtr TrackTarget() const = 0;
281
286  public: virtual void SetTrackOffset(const math::Vector3d &_offset) = 0;
287
291  public: virtual math::Vector3d TrackOffset() const = 0;
292
296  public: virtual void SetTrackPGain(const double _pGain) = 0;
297
300  public: virtual double TrackPGain() const = 0;
301
313  public: virtual void SetFollowTarget(const NodePtr &_target,
314  const math::Vector3d &_offset = math::Vector3d::Zero,
315  const bool _worldFrame = false) = 0;
316
319  public: virtual NodePtr FollowTarget() const = 0;
320
325  public: virtual void SetFollowOffset(const math::Vector3d &_offset) = 0;
326
330  public: virtual math::Vector3d FollowOffset() const = 0;
331
335  public: virtual void SetFollowPGain(const double _pGain) = 0;
336
339  public: virtual double FollowPGain() const = 0;
340
343  public: virtual void SetMaterial(const MaterialPtr &_material) = 0;
344
349  public: virtual unsigned int RenderTextureGLId() const = 0;
350
357  public: virtual void RenderTextureMetalId(void *_textureIdPtr) const = 0;
358
363  public: virtual void PrepareForExternalSampling() = 0;
364
367  public: virtual void AddRenderPass(const RenderPassPtr &_pass) = 0;
368
371  public: virtual void RemoveRenderPass(const RenderPassPtr &_pass) = 0;
372
374  public: virtual void RemoveAllRenderPasses() = 0;
375
378  public: virtual unsigned int RenderPassCount() const = 0;
379
382  public: virtual RenderPassPtr RenderPassByIndex(unsigned int _index)
383  const = 0;
384
387  public: virtual void SetShadowsDirty() = 0;
388  };
389  }
390  }
391 }
392
393 #if defined(__GNUC__) || defined(__clang__)
394 # pragma GCC diagnostic pop
395 #endif
396
397 #endif
