insert_drive_file
Tutorials
library_books
toc
insert_drive_file
Files
launch
Gazebo Website
Index
List
Hierarchy
Members: All
Members: Functions
Members: Variables
Members: Typedefs
Members: Enumerations
Members: Enumerator
List
Members
Functions
Variables
Enumerations
Enumerator
src
gz-rendering
include
gz
rendering
Storage.hh
1
2
* Copyright (C) 2015 Open Source Robotics Foundation
3
4
* Licensed under the Apache License, Version 2.0 (the "License");
5
* you may not use this file except in compliance with the License.
6
* You may obtain a copy of the License at
7
8
* http://www.apache.org/licenses/LICENSE-2.0
9
10
* Unless required by applicable law or agreed to in writing, software
11
* distributed under the License is distributed on an "AS IS" BASIS,
12
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
13
* See the License for the specific language governing permissions and
14
* limitations under the License.
15
16
17
#ifndef GZ_RENDERING_STORAGE_HH_
18
#define GZ_RENDERING_STORAGE_HH_
20
#include <memory>
21
#include <string>
22
#include "gz/rendering/config.hh"
23
#include "
gz/rendering/Scene.hh
24
#include "
gz/rendering/Node.hh
25
#include "
gz/rendering/Light.hh
26
#include "
gz/rendering/Sensor.hh
27
#include "
gz/rendering/Visual.hh
28
#include "
gz/rendering/Geometry.hh
29
#include "
gz/rendering/Material.hh
30
#include "
gz/rendering/Mesh.hh
31
#include "gz/rendering/Export.hh"
32
33
// An X11 header file defines a macro that conflicts with our function name,
34
// so undefine it here
35
#ifdef DestroyAll
36
#undef DestroyAll
37
#endif
38
39
namespace
gz
40
41
namespace
rendering
42
43
inline
namespace
GZ_RENDERING_VERSION_NAMESPACE {
44
48
template
class
T>
49
class
GZ_RENDERING_VISIBLE
Map
50
53
typedef
std::shared_ptr<T>
TPtr
54
57
typedef
std::shared_ptr<const T>
ConstTPtr
58
60
public
~Map
default
61
64
public
unsigned
int
Size
const
= 0;
65
69
public
bool
ContainsKey
const
std::string
&_key)
const
= 0;
70
74
public
bool
ContainsValue
ConstTPtr
_value)
const
= 0;
75
79
public
TPtr
Get
const
std::string
&_key)
const
= 0;
80
84
public
TPtr
GetByIndex
unsigned
int
_index)
const
= 0;
85
91
public
bool
Put
const
std::string
&_key,
TPtr
_value) = 0;
92
96
public
void
Remove
const
std::string
&_key) = 0;
97
101
public
void
Remove
TPtr
_value) = 0;
102
104
public
void
RemoveAll
() = 0;
105
106
113
template
class
T>
114
class
Store
115
118
typedef
std::shared_ptr<T>
TPtr
119
122
typedef
ConstTPtr
123
125
public
~Store
default
126
129
public
unsigned
int
Size
const
= 0;
130
134
public
bool
Contains
ConstTPtr
_object)
const
= 0;
135
139
public
bool
ContainsId
unsigned
int
_id)
const
= 0;
140
144
public
bool
ContainsName
const
std::string
&_name)
const
= 0;
145
149
public
TPtr
GetById
unsigned
int
_id)
const
= 0;
150
154
public
TPtr
GetByName
const
std::string
&_name)
const
= 0;
155
159
public
TPtr
GetByIndex
unsigned
int
_index)
const
= 0;
160
166
public
bool
Add
TPtr
_object) = 0;
167
172
public
TPtr
Remove
TPtr
_object) = 0;
173
178
public
TPtr
RemoveById
unsigned
int
_id) = 0;
179
184
public
TPtr
RemoveByName
const
std::string
&_name) = 0;
185
190
public
TPtr
RemoveByIndex
unsigned
int
_index) = 0;
191
193
public
void
RemoveAll
() = 0;
194
198
public
void
Destroy
TPtr
_object) = 0;
199
203
public
void
DestroyById
unsigned
int
_id) = 0;
204
209
public
void
DestroyByName
const
std::string
&_name) = 0;
210
215
public
void
DestroyByIndex
unsigned
int
_index) = 0;
216
218
public
void
DestroyAll
() = 0;
219
220
226
template
class
T>
227
class
CompositeStore
228
public
Store
<T>
229
232
typedef
std::shared_ptr<T>
TPtr
233
236
typedef
Store<T>
TStore
237
240
typedef
std::shared_ptr<TStore>
TStorePtr
241
244
typedef
std::shared_ptr<const TStore>
ConstTStorePtr
245
247
public
~CompositeStore
default
248
251
public
unsigned
int
GetStoreCount
const
= 0;
252
256
public
bool
ContainsStore
ConstTStorePtr
_store)
const
= 0;
257
262
public
bool
AddStore
TStorePtr
_store) = 0;
263
268
public
TStorePtr
GetStore
unsigned
int
_index)
const
= 0;
269
274
public
TStorePtr
RemoveStore
TStorePtr
_store) = 0;
275
280
public
TStorePtr
RemoveStore
unsigned
int
_index) = 0;
281
282
290
template
class
T,
class
U>
291
class
StoreWrapper
292
public
Store
<T>
293
294
public
~StoreWrapper
default
295
296
297
// armhf failed to build with this code. It can not be removed for the rest
298
// of arches to keep ABI but should be removed in major versions unreleased
299
// see https://github.com/gazebosim/gz-rendering/pull/457
300
#ifndef __ARM_PCS_VFP
301
template
class
Store<Scene>
302
template
class
Store<Node>
303
template
class
Store<Light>
304
template
class
Store<Sensor>
305
template
class
Store<Visual>
306
template
class
Store<Geometry>
307
template
class
Store<SubMesh>
308
template
class
Map<Material>
309
template
class
CompositeStore<Node>
310
#endif
311
314
typedef
Store<Scene>
SceneStore
315
318
typedef
Store<Node>
NodeStore
319
322
typedef
Store<Light>
LightStore
323
326
typedef
Store<Sensor>
SensorStore
327
330
typedef
Store<Visual>
VisualStore
331
334
typedef
Store<Geometry>
GeometryStore
335
338
typedef
Store<SubMesh>
SubMeshStore
339
342
typedef
Map<Material>
MaterialMap
343
346
typedef
NodeCompositeStore
347
350
typedef
std::shared_ptr<SceneStore>
SceneStorePtr
351
354
typedef
std::shared_ptr<NodeStore>
NodeStorePtr
355
358
typedef
std::shared_ptr<LightStore>
LightStorePtr
359
362
typedef
std::shared_ptr<SensorStore>
SensorStorePtr
363
366
typedef
std::shared_ptr<VisualStore>
VisualStorePtr
367
370
typedef
std::shared_ptr<GeometryStore>
GeometryStorePtr
371
374
typedef
std::shared_ptr<SubMeshStore>
SubMeshStorePtr
375
378
typedef
std::shared_ptr<MaterialMap>
MaterialMapPtr
379
382
typedef
std::shared_ptr<NodeCompositeStore>
NodeCompositeStorePtr
383
384
385
386
#endif
