StoreWrapper< T, U > Class Template Reference
#include <gz/rendering/StoreWrapper.hh>
virtual ~StoreWrapper ()=default
virtual ~Store ()=default
virtual void DestroyAll ()=0
virtual void RemoveAll ()=0
template<class T, class U>
class gz::rendering::StoreWrapper< T, U >
Template Parameters
TNew storage type
USome derived class of T
◆ ~StoreWrapper()
virtual ~StoreWrapper ( )
virtualdefault
