BaseInertiaVisual< T > Class Template Reference
Base implementation of an inertia visual. More...
#include <BaseInertiaVisual.hh>
virtual ~BaseInertiaVisual ()
virtual VisualPtr BoxVisual () const override
 Get the box visual. More...
virtual void Load (const gz::math::Pose3d &, const gz::math::Vector3d &) override
virtual ~InertiaVisual ()
template<class T>
class gz::rendering::BaseInertiaVisual< T >
◆ BaseInertiaVisual()
BaseInertiaVisual
◆ ~BaseInertiaVisual()
◆ BoxVisual()
VisualPtr BoxVisual ( ) const
Get the box visual.
Pointer to the box visual
Implements InertiaVisual.
Reimplemented in Ogre2InertiaVisual, and OgreInertiaVisual.
void Init
◆ Load()
void Load ( const gz::math::Pose3d &  _pose,
const gz::math::Vector3d &  _scale
void PreRender ( )
◆ SetInertial()
void SetInertial ( const gz::math::Inertiald &  _inertial)
References gzlog, Inertial< class >::MassMatrix(), and Inertial< class >::Pose().
