BasePointLight< T > Class Template Reference
#include <BaseLight.hh>
virtual ~BasePointLight ()
- Public Member Functions inherited from PointLight
virtual ~PointLight ()
virtual ~Light ()
 BasePointLight ()
◆ BasePointLight()
BasePointLight
◆ ~BasePointLight()
~BasePointLight
