A base implementation of the Projector class. More...
#include <BaseProjector.hh>
virtual ~BaseProjector ()
 Get the projector's far clipping plane distance. More...
 Get the projector's horizontal field-of-view. More...
bool IsEnabled () const override
 Get whether the projector is enabled or disabled. More...
 Get the projector's near clipping plane distance. More...
void SetEnabled (bool _enabled) override
 Set whether the projector is enabled or disabled. More...
virtual void SetFarClipPlane (double _far) override
 Set the projector's far clipping plane distance. More...
 Set the projector's horizontal field-of-view. More...
virtual void SetNearClipPlane (double _near) override
 Set the projector's near clipping plane distance. More...
void SetTexture (const std::string &_texture) override
 Load a texture into the projector. More...
 Get the URI of the texture file used by the projector. More...
- Public Member Functions inherited from Projector
virtual ~Projector ()
 BaseProjector ()
bool enabled = false
 Indicates whether or not the projector is enabled. More...
double farClip = 10.0
 Projector's far clip plane. More...
math::Angle hfov = math::Angle(0.785398)
 Projector's horizontal field of view. More...
double nearClip = 0.1
 Projector's near clip plane. More...
std::string textureName
 Texture used by the projector. More...
template<class T>
class gz::rendering::BaseProjector< T >
◆ BaseProjector()
BaseProjector
◆ ~BaseProjector()
~BaseProjector
◆ FarClipPlane()
double FarClipPlane ( ) const
Far clipping plane distance
Implements Projector.
◆ HFOV()
math::Angle HFOV ( ) const
Angle containing the projector's horizontal field-of-view
◆ IsEnabled()
bool IsEnabled ( ) const
true if enabled, false otherwise
◆ NearClipPlane()
Near clipping plane distance
◆ SetEnabled()
void SetEnabled ( bool  _enabled)
[in]_enabledTrue to enable the projector.
◆ SetFarClipPlane()
void SetFarClipPlane ( double  _far)
◆ SetHFOV()
void SetHFOV ( const math::Angle &  _hfov)
◆ SetNearClipPlane()
void SetNearClipPlane ( double  _near)
◆ SetTexture()
void SetTexture ( const std::string &  _texture)
[in]_textureName of the texture to project.
◆ Texture()
std::string Texture ( ) const
◆ enabled
◆ farClip
◆ hfov
◆ nearClip
◆ textureName
