BaseSensorStore< T > Class Template Reference
#include <BaseStorage.hh>
- Public Member Functions inherited from BaseStore< Sensor, T >
 BaseStore ()
virtual ~BaseStore ()
virtual UIter Begin ()
virtual void DestroyAll ()
virtual UIter End ()
virtual void RemoveAll ()
virtual ~Store ()=default
- Protected Member Functions inherited from BaseStore< Sensor, T >
 Get a const iterator to the object by pointer. Note that the iterator may change or become invalid when objects are added to / removed from the store. More...
 Get a const iterator to the object by id. Note that the iterator may change or become invalid when objects are added to / removed from the store. More...
 Get a const iterator to the object by index. Note that the iterator may change or become invalid when objects are added to / removed from the store. More...
 Get a const iterator to the object by name. Note that the iterator may change or become invalid when objects are added to / removed from the store. More...
 Get an iterator to the object by pointer. Note that the iterator may change or become invalid when objects are added to / removed from the store. More...
 Get an iterator to the object by id. Note that the iterator may change or become invalid when objects are added to / removed from the store. More...
 Get an iterator to the object by index. Note that the iterator may change or become invalid when objects are added to / removed from the store. More...
 Get an iterator to the object by name. Note that the iterator may change or become invalid when objects are added to / removed from the store. More...
- Protected Attributes inherited from BaseStore< Sensor, T >
UStore store
UStoreMap storeMap
