Capsule Class Referenceabstract
Geometry for a capsule shape. The APIs allow setting the capsule's radius and length directly which ensure that the the geometry remains the shape of a capsule. In comparison, if the size is changed via the parent Node's Set*Scale function, the capsule may become deformed. More...
#include <gz/rendering/Capsule>
virtual ~Capsule ()
virtual double Length () const =0
 Get the length of the capsule. More...
virtual double Radius () const =0
 Get the radius of the capsule. More...
virtual void SetLength (double _length)=0
 Set the length of the capsule. More...
virtual void SetRadius (double _radius)=0
 Set the radius of the capsule. More...
 Clone the geometry. More...
◆ ~Capsule()
virtual ~Capsule ( )
◆ Length()
virtual double Length ( ) const
Implemented in BaseCapsule< T >, BaseCapsule< Ogre2Geometry >, and BaseCapsule< OgreGeometry >.
◆ Radius()
virtual double Radius ( ) const
◆ SetLength()
virtual void SetLength ( double  _length)
◆ SetRadius()
virtual void SetRadius ( double  _radius)
