DepthCamera Class Referenceabstract
#include <DepthCamera.hh>
Public Types
virtual ~DepthCamera ()
virtual gz::common::ConnectionPtr ConnectNewDepthFrame (std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)=0
 Connect to the new depth image signal. More...
virtual gz::common::ConnectionPtr ConnectNewRgbPointCloud (std::function< void(const float *_pointCloud, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &_format)> _subscriber)=0
 Connect to the new rgb point cloud signal. More...
virtual void CreateDepthTexture ()=0
 Create a texture which will hold the depth data. More...
virtual const float * DepthData () const =0
 All things needed to get back z buffer for depth data. More...
virtual ~Camera ()
 Performs any necessary final rendering work. Once rendering is complete the camera will alert any listeners of the new frame event. This function should only be called after a call to Render has successfully been executed. More...
virtual void PrepareForExternalSampling ()=0
 Right now this is Vulkan-only. This function needs to be called after rendering, and before handling the texture pointer (i.e. by calling RenderTextureMetalId()) so that external APIs (e.g. Qt) can sample the texture. More...
 Remove all render passes from the camera. More...
virtual void Render ()=0
virtual void RenderTextureMetalId (void *_textureIdPtr) const =0
virtual void SetImageFormat (PixelFormat _format, bool _reinterpretable=false)=0
virtual void Update ()=0
virtual VisualPtr VisualAt (const gz::math::Vector2i &_mousePos)=0
 Sensor. More...
 Set visibility mask. More...
 Get visibility mask. More...
Member Typedef Documentation
◆ NewFrameListener
typedef std::function<void(const void*, unsigned int, unsigned int, unsigned int, const std::string&)> NewFrameListener
◆ ~DepthCamera()
virtual ~DepthCamera ( )
◆ ConnectNewDepthFrame()
virtual gz::common::ConnectionPtr ConnectNewDepthFrame ( std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
Implemented in Ogre2DepthCamera, OgreDepthCamera, BaseDepthCamera< T >, BaseDepthCamera< Ogre2Sensor >, and BaseDepthCamera< OgreSensor >.
◆ ConnectNewRgbPointCloud()
virtual gz::common::ConnectionPtr ConnectNewRgbPointCloud ( std::function< void(const float *_pointCloud, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &_format)>  _subscriber)
[in]_subscriberSubscriber callback function The arguments of the callback function are: _pointCloud Point cloud data. Each point is represented by four 32 bit floating point values [X, Y, Z, RGBA]. The last field can be decoded into 4 unsigned 8 bit color values: uint32_t *rgba = reinterpret_cast<uint32_t *>(&_rgba) r = static_cast<uint8_t>(*rgba >> 24 & 0xFF); g = static_cast<uint8_t>(*rgba >> 16 & 0xFF); b = static_cast<uint8_t>(*rgba >> 8 & 0xFF); a = static_cast<uint8_t>(*rgba >> 0 & 0xFF); _width Point cloud image width _height Point cloud image height _depth Point cloud image depth _format Point cloud image format
◆ CreateDepthTexture()
virtual void CreateDepthTexture ( )
◆ DepthData()
virtual const float* DepthData ( ) const
The z-buffer as a float array
