Ogre2GlobalIlluminationVct Class Reference
Ogre2.x implementation of the GlobalIlluminationVct class. More...
#include <Ogre2GlobalIlluminationVct.hh>
virtual ~Ogre2GlobalIlluminationVct () override
virtual bool Anisotropic () const override
 Whether anisotropic setting is on. More...
virtual uint32_t BounceCount () const override
 Get number of bounces. More...
virtual void Build () override
 Build the internal structures required for producing GI This function may take significant time. More...
virtual bool ConserveMemory () const override
 Whether we're releasing memory as fast as possible. More...
virtual DebugVisualizationMode DebugVisualization () const override
 Returns current visualization mode. More...
virtual bool Enabled () const override
 Returns true if this GI configuration is currently enabled. More...
virtual bool HighQuality () const override
 Whether we're using 6 (true) or 4 (false) cones. More...
virtual void LightingChanged () override
 Called by Scene when lighting changes so that GI can be updated. More...
virtual const uint32_t * OctantCount () const override
 Returns number of octant subdivisions per axis. More...
uint32_t ParticipatingVisuals () const override
 Visuals that can bounce GI. More...
virtual const uint32_t * Resolution () const override
 Returns 3D Voxel resolution. More...
virtual void SetAnisotropic (bool _anisotropic) override
 Anisotropic VCT provides much higher quality because it better captures incoming indirect illumination from all directions. More...
virtual void SetBounceCount (uint32_t _bounceCount) override
 Set the number of GI bounces. Very high number can cause a large performance impact. More...
virtual void SetConserveMemory (bool _conserveMemory) override
 This will try to release resources that aren't needed when lights and static objects don't change. More...
virtual void SetDebugVisualization (DebugVisualizationMode _dvm) override
 Draws the voxels on screen for inspection and understand what is going on with GI. You should be looking at a minecraft-like world. More...
virtual void SetHighQuality (bool _highQuality) override
 True for high quality (slower). VRAM consumption stays the same. Ogre2 will use 6 cones instead of 4. More...
virtual void SetOctantCount (const uint32_t _octants[3]) override
 Number of divisions per axis to divide the scene into multiple octants. Setting this value > 1 may improve voxelization performance when there is a lot of static Meshes; but it may also decrease it. Profiling is required for each scene. More...
void SetParticipatingVisuals (uint32_t _mask) override
 Set which visuals can bounce GI. More...
virtual void SetResolution (const uint32_t _resolution[3]) override
 Resolution of the 3D Voxel. Must be multiple of 2. More...
virtual void SetThinWallCounter (float _thinWallCounter) override
 Shadows are calculated by raymarching towards the light source. However sometimes the ray 'may go through' a wall due to how bilinear interpolation works. More...
virtual float ThinWallCounter () const override
 Value of SetThinWallCounter. More...
virtual void UpdateCamera () override
 Called by Scene on an active GlobalIlluminationBase whenever first rendering happens for a new frame. This implies Build has been called already. More...
virtual void UpdateLighting () override
 Called by Scene on an active GlobalIlluminationBase whenever lighting changes. This implies Build has been called already. More...
- Public Member Functions inherited from BaseGlobalIlluminationVct< Ogre2Object >
virtual ~BaseGlobalIlluminationVct ()
- Public Member Functions inherited from GlobalIlluminationVct
virtual ~GlobalIlluminationVct ()
- Public Member Functions inherited from GlobalIlluminationBase
 GlobalIlluminationBase ()
virtual ~GlobalIlluminationBase ()
 Sets this GI solution as enabled. More...
- Protected Member Functions inherited from BaseGlobalIlluminationVct< Ogre2Object >
- Public Types inherited from GlobalIlluminationVct
enum  DebugVisualizationMode {
  DVM_Albedo , DVM_Normal , DVM_Emissive , DVM_Lighting ,
  DVM_None
 Debug visualization modes for GlobalIlluminationVct::SetDebugVisualization. More...
- Public Types inherited from GlobalIlluminationBase
enum  ParticipatingVisualsFlags { DYNAMIC_VISUALS = 1u << 0u , STATIC_VISUALS = 1u << 1u }
 Bitmask of which objects are considered by GI bounces. Note that all objects can receive indirect illumination. More...
◆ Ogre2GlobalIlluminationVct()
◆ ~Ogre2GlobalIlluminationVct()
virtual ~Ogre2GlobalIlluminationVct ( )
◆ Anisotropic()
virtual bool Anisotropic ( ) const
Anisotropy setting
Reimplemented from BaseGlobalIlluminationVct< Ogre2Object >.
◆ BounceCount()
virtual uint32_t BounceCount ( ) const
Number of bounces
Implements GlobalIlluminationBase.
◆ Build()
virtual void Build ( )
◆ ConserveMemory()
virtual bool ConserveMemory ( ) const
Conserve Memory setting
◆ DebugVisualization()
virtual DebugVisualizationMode DebugVisualization ( ) const
Visualization mode
Implements GlobalIlluminationVct.
◆ Enabled()
virtual bool Enabled ( ) const
True if this GI solution is currently enabled
◆ HighQuality()
virtual bool HighQuality ( ) const
High Quality setting
◆ LightingChanged()
virtual void LightingChanged ( )
◆ OctantCount()
virtual const uint32_t* OctantCount ( ) const
Octant subdivisions. Length of array is 3
◆ ParticipatingVisuals()
uint32_t ParticipatingVisuals ( ) const
See ParticipatingVisualsFlags
◆ Resolution()
virtual const uint32_t* Resolution ( ) const
Resolution in each axis. Length of array is 3
◆ SetAnisotropic()
virtual void SetAnisotropic ( bool  _anisotropic)
However it consumes more VRAM and is slower. Recommended: true
Remarks
This setting has nothing to do with anistropic texture filtering in GPUs
[in]_anisotropicAnisotropy setting
◆ SetBounceCount()
virtual void SetBounceCount ( uint32_t  _bounceCount)
[in]_bounceCountValue in range [0; inf)
◆ SetConserveMemory()
virtual void SetConserveMemory ( bool  _conserveMemory)
When true, every time light changes we will recreate those resources, update the GI, and release them; causing VRAM spikes. This can be bad for memory fragmentation (and performance) if VCT is updated too often.
When false, those resources will stay loaded at all times
[in]_conserveMemoryTrue to release memory as fast as possible
◆ SetDebugVisualization()
virtual void SetDebugVisualization ( DebugVisualizationMode  _dvm)
[in]_dvmWhat component to visualize
◆ SetEnabled()
Remarks
Only one GI solution can be active at the same time
Scene::SetActiveGlobalIllumination
[in]_enabledTrue to enable, false otherwise
◆ SetHighQuality()
virtual void SetHighQuality ( bool  _highQuality)
[in]_highQualityQuality setting
◆ SetOctantCount()
virtual void SetOctantCount ( const uint32_t  _octants[3])
[in]_octantsNumber of octant subdivisions per axis
◆ SetParticipatingVisuals()
void SetParticipatingVisuals ( uint32_t  _mask)
[in]_maskSee ParticipatingVisualsFlags
◆ SetResolution()
virtual void SetResolution ( const uint32_t  _resolution[3])
Remarks
To avoid wasting RAM, make this function your first call if you intend to change the defaults.
[in]_resolutionResolution
◆ SetThinWallCounter()
virtual void SetThinWallCounter ( float  _thinWallCounter)
Bilinear interpolation can produce nicer soft shadows, but it can also cause this light leaking from behind a wall.
Increase this value (e.g. to 2.0f) to fight light leaking. This should generally (over-)darken the scene
Lower values will lighten the scene and allow more light leaking
Note that thinWallCounter can not fight all sources of light leaking, thus increasing it to ridiculous high values may not yield any benefit.
[in]_thinWallCounterValue in range (0; inf)
◆ ThinWallCounter()
virtual float ThinWallCounter ( ) const
ThingWallCounter value
◆ UpdateCamera()
virtual void UpdateCamera ( )
◆ UpdateLighting()
virtual void UpdateLighting ( )
