GlobalIlluminationBase Class Referenceabstract
There can be many global illumination solutions. More...
#include <GlobalIlluminationBase.hh>
Public Types
enum  ParticipatingVisualsFlags { DYNAMIC_VISUALS = 1u << 0u , STATIC_VISUALS = 1u << 1u }
 Bitmask of which objects are considered by GI bounces. Note that all objects can receive indirect illumination. More...
 GlobalIlluminationBase ()
virtual ~GlobalIlluminationBase ()
virtual uint32_t BounceCount () const =0
 Get number of bounces. More...
virtual void Build ()=0
 Build the internal structures required for producing GI This function may take significant time. More...
virtual bool Enabled () const =0
 Returns true if this GI configuration is currently enabled. More...
virtual uint32_t ParticipatingVisuals () const =0
 Visuals that can bounce GI. More...
virtual void SetBounceCount (uint32_t _bounceCount)=0
 Set the number of GI bounces. Very high number can cause a large performance impact. More...
virtual void SetParticipatingVisuals (uint32_t _mask)=0
 Set which visuals can bounce GI. More...
virtual void UpdateCamera ()=0
 Called by Scene on an active GlobalIlluminationBase whenever first rendering happens for a new frame. This implies Build has been called already. More...
virtual void UpdateLighting ()=0
 Called by Scene on an active GlobalIlluminationBase whenever lighting changes. This implies Build has been called already. More...
 Destroy the class. More...
virtual void Init ()=0
 Initialize the class. More...
 Sets this GI solution as enabled. More...
gz/rendering/GlobalIlluminationBase.hh
This class is the base of them all for (most) shared settings
◆ ParticipatingVisualsFlags
However often only static objects can reflect/bounce/cast indirect illumination
Enumerator
DYNAMIC_VISUALS
Dynamic objects can bounce GI (depending on the solution, this may be slow)
STATIC_VISUALS
Static objects can bounce GI.
◆ GlobalIlluminationBase()
◆ ~GlobalIlluminationBase()
virtual ~GlobalIlluminationBase ( )
◆ BounceCount()
virtual uint32_t BounceCount ( ) const
Number of bounces
Implemented in Ogre2GlobalIlluminationVct, and Ogre2GlobalIlluminationCiVct.
◆ Build()
virtual void Build ( )
protectedpure virtual
Destroy the class.
◆ Enabled()
virtual bool Enabled ( ) const
True if this GI solution is currently enabled
◆ ParticipatingVisuals()
virtual uint32_t ParticipatingVisuals ( ) const
See ParticipatingVisualsFlags
◆ SetBounceCount()
virtual void SetBounceCount ( uint32_t  _bounceCount)
[in]_bounceCountValue in range [0; inf)
◆ SetEnabled()
Remarks
Only one GI solution can be active at the same time
Scene::SetActiveGlobalIllumination
[in]_enabledTrue to enable, false otherwise
◆ SetParticipatingVisuals()
virtual void SetParticipatingVisuals ( uint32_t  _mask)
[in]_maskSee ParticipatingVisualsFlags
◆ UpdateCamera()
virtual void UpdateCamera ( )
◆ UpdateLighting()
virtual void UpdateLighting ( )
