Ogre2GlobalIlluminationCiVct Class Reference
Ogre2.x implementation of the GlobalIlluminationCiVct class. More...
#include <Ogre2GlobalIlluminationCiVct.hh>
virtual ~Ogre2GlobalIlluminationCiVct () override
virtual CiVctCascadePtr AddCascade (const CiVctCascade *_ref) override
 Adds a new cascade. More...
virtual bool Anisotropic () const override
 Whether anisotropic setting is on. More...
virtual void AutoCalculateStepSizes (const gz::math::Vector3d &_stepSize) override
 Alters each cascade's step size. The last cascade is set to stepSize. The rest of the cascades are set to step sizes that are >= stepSize automatically. Should be called after adding all cascades. More...
virtual void Bind (const CameraPtr &_camera) override
 CIVCT relies on having multiple cascades around a central position, typically a camera. This function binds a camera for us to monitor and will act as the center of those cascades. More...
virtual uint32_t BounceCount () const override
 Get number of bounces. More...
virtual void Build () override
 Build the internal structures required for producing GI This function may take significant time. More...
virtual bool ConsistentCascadeSteps () const override
 Retrieve current setting. See SetConsistentCascadeSteps. More...
virtual DebugVisualizationMode DebugVisualization () const override
 Returns current visualization mode. More...
virtual bool Enabled () const override
 Returns true if this GI configuration is currently enabled. More...
virtual bool HighQuality () const override
 Whether we're using 6 (true) or 4 (false) cones. More...
virtual void LightingChanged () override
 Called by Scene when lighting changes so that GI can be updated. More...
virtual void NewSettings (uint32_t _bounceCount, bool _anisotropic) override
 Sets new settings after having called Init. More...
uint32_t ParticipatingVisuals () const override
 Visuals that can bounce GI. More...
virtual void PopCascade () override
 Removes the last added cascade. More...
virtual void Reset () override
 Disables this GI and undoes the internal work performed by Start(). This makes it possible to edit cascades again. More...
virtual void SetBounceCount (uint32_t _bounceCount) override
 Set the number of GI bounces. Very high number can cause a large performance impact. More...
virtual void SetConsistentCascadeSteps (bool _consistentCascadeSteps) override
 Selects how we determine when we need to (partially) rebuild the voxels based on camera movement. More...
virtual void SetDebugVisualization (DebugVisualizationMode _dvm) override
 Draws the voxels on screen for inspection and understand what is going on with GI. You should be looking at a minecraft-like world. More...
virtual void SetHighQuality (bool _highQuality) override
 True for high quality (slower). VRAM consumption stays the same. Ogre2 will use 6 cones instead of 4. More...
virtual void SetMaxCascades (const uint32_t _maxCascades) override
 Tells how many times AddCascade will be called. You can call it fewer times (i.e. some kb of RAM will be wasted) but not more. More...
void SetParticipatingVisuals (uint32_t _mask) override
 Set which visuals can bounce GI. More...
virtual void Start (uint32_t _bounceCount, bool _anisotropic) override
 Call this function after adding all cascades. You can no longer add cascades after this. More...
virtual bool Started () const override
 Returns true if Start() has already been called. Will return false again if Reset() is called. More...
virtual void UpdateCamera () override
 Called by Scene on an active GlobalIlluminationBase whenever first rendering happens for a new frame. This implies Build has been called already. More...
virtual void UpdateLighting () override
 Called by Scene on an active GlobalIlluminationBase whenever lighting changes. This implies Build has been called already. More...
- Public Member Functions inherited from GlobalIlluminationCiVct
virtual ~GlobalIlluminationCiVct ()
- Public Member Functions inherited from GlobalIlluminationBase
 GlobalIlluminationBase ()
virtual ~GlobalIlluminationBase ()
 Sets this GI solution as enabled. More...
- Public Types inherited from GlobalIlluminationCiVct
enum  DebugVisualizationMode {
  DVM_Albedo , DVM_Normal , DVM_Emissive , DVM_Lighting ,
  DVM_None
 Debug visualization modes for GlobalIlluminationCiVct::SetDebugVisualization. More...
- Public Types inherited from GlobalIlluminationBase
enum  ParticipatingVisualsFlags { DYNAMIC_VISUALS = 1u << 0u , STATIC_VISUALS = 1u << 1u }
 Bitmask of which objects are considered by GI bounces. Note that all objects can receive indirect illumination. More...
◆ Ogre2GlobalIlluminationCiVct()
◆ ~Ogre2GlobalIlluminationCiVct()
virtual ~Ogre2GlobalIlluminationCiVct ( )
◆ AddCascade()
virtual CiVctCascadePtr AddCascade ( const CiVctCascade *  _ref)
Adds a new cascade.
Remarks
Cannot be called anymore after Start() has been called
[in]_refCan be nullptr. If you already have a cascade, we will clone its settings.
New Cascade to control its settings.
Implements GlobalIlluminationCiVct.
◆ Anisotropic()
virtual bool Anisotropic ( ) const
Anisotropy setting
◆ AutoCalculateStepSizes()
virtual void AutoCalculateStepSizes ( const gz::math::Vector3d &  _stepSize)
[in]_stepSizeSee CiVctCascade::SetCameraStepSize
◆ Bind()
virtual void Bind ( const CameraPtr &  _camera)
Remarks
If no camera is bound, the active camera will be used, which can cause performance problems if multiple sensors are present
[in]_cameraCamera to bind. Nullptr to unbind.
◆ BounceCount()
virtual uint32_t BounceCount ( ) const
Number of bounces
Implements GlobalIlluminationBase.
◆ Build()
virtual void Build ( )
◆ ConsistentCascadeSteps()
virtual bool ConsistentCascadeSteps ( ) const
True if the feature is enabled
◆ DebugVisualization()
virtual DebugVisualizationMode DebugVisualization ( ) const
Visualization mode
◆ Enabled()
virtual bool Enabled ( ) const
True if this GI solution is currently enabled
◆ HighQuality()
virtual bool HighQuality ( ) const
High Quality setting
◆ LightingChanged()
virtual void LightingChanged ( )
◆ NewSettings()
virtual void NewSettings ( uint32_t  _bounceCount,
bool  _anisotropic
[in]_bounceCountSee Start
[in]_anisotropicSee Start
◆ ParticipatingVisuals()
uint32_t ParticipatingVisuals ( ) const
See ParticipatingVisualsFlags
◆ PopCascade()
virtual void PopCascade ( )
Remarks
Do NOT try to call any of the functions of the CiVctCascadePtr returned by AddCascade after this call.
◆ Reset()
virtual void Reset ( )
◆ SetBounceCount()
virtual void SetBounceCount ( uint32_t  _bounceCount)
[in]_bounceCountValue in range [0; inf)
◆ SetConsistentCascadeSteps()
virtual void SetConsistentCascadeSteps ( bool  _consistentCascadeSteps)
Remarks
If camera movement is deterministic, output is always deterministic regardless of this setting
[in]_consistentCascadeStepsTrue: Results can feel very determnistic because it is predictable.
Camera position is quantized in voxelCellSize * cascade.cameraStepSize. This means the camera position is in a 'cell' or 'grid'.
When the camera position moves onto another grid, we partially revoxelize results.
Advantage: A camera at pos XYZ will always have the same results
Disadvantage: if the camera jumps back and forth between voxels, revoxelizations will trigger frequently causing obvious frequent jumps in brightness
False: Revoxelization happens after the camera has travelled cascade.cameraStepSize cells away from the last point of voxelization.
Advantage: Infrequent revoxelizations. If camera movement is restricted around the last voxelization point, we will never revoxelize.
Disadvantage: Taking a picture at pos XYZ, then going away, and taking another picture at same pos XYZ may not result in the same brightness / image; which can make it feel unpredictable or non-deterministic. This can be workarounded by temporarily setting SetConsistentCascadeSteps(true) then back false after taking the picture
◆ SetDebugVisualization()
virtual void SetDebugVisualization ( DebugVisualizationMode  _dvm)
[in]_dvmWhat component to visualize
◆ SetEnabled()
Remarks
Only one GI solution can be active at the same time
Scene::SetActiveGlobalIllumination
[in]_enabledTrue to enable, false otherwise
◆ SetHighQuality()
virtual void SetHighQuality ( bool  _highQuality)
[in]_highQualityQuality setting
◆ SetMaxCascades()
virtual void SetMaxCascades ( const uint32_t  _maxCascades)
Remarks
You can't call this function after adding cascades The semantics are similar to std::vector::reserve
[in]_maxCascadesNumber of times AddCascade will be called
◆ SetParticipatingVisuals()
void SetParticipatingVisuals ( uint32_t  _mask)
[in]_maskSee ParticipatingVisualsFlags
◆ Start()
virtual void Start ( uint32_t  _bounceCount,
bool  _anisotropic
[in]_bounceCountNumber of bounces for cascade 0. The rest of the cascades are autocalculated to maintain even brightness levels.
Range is [0; inf) but a value of 0 is strongly discouraged if you have more than 1 cascade as you can end up with very uneven brightness levels between cascades For more info see Ogre's VctLighting::update
[in]_anisotropicWhether we should use anisotropic VCT (higher quality, but consumes more VRAM). See GlobalIlluminationVct::SetAnisotropic
◆ Started()
virtual bool Started ( ) const
◆ UpdateCamera()
virtual void UpdateCamera ( )
◆ UpdateLighting()
virtual void UpdateLighting ( )
