GlobalIlluminationCiVct Class Referenceabstract
Implements Global Illumination using CIVCT (Cascaded Image Voxel Cone Tracing) More...
#include <GlobalIlluminationCiVct.hh>
Public Types
enum  DebugVisualizationMode {
  DVM_Albedo , DVM_Normal , DVM_Emissive , DVM_Lighting ,
  DVM_None
 Debug visualization modes for GlobalIlluminationCiVct::SetDebugVisualization. More...
- Public Types inherited from GlobalIlluminationBase
enum  ParticipatingVisualsFlags { DYNAMIC_VISUALS = 1u << 0u , STATIC_VISUALS = 1u << 1u }
 Bitmask of which objects are considered by GI bounces. Note that all objects can receive indirect illumination. More...
 GlobalIlluminationCiVct ()
virtual ~GlobalIlluminationCiVct ()
virtual CiVctCascadePtr AddCascade (const CiVctCascade *_ref)=0
 Adds a new cascade. More...
virtual bool Anisotropic () const =0
 Whether anisotropic setting is on. More...
virtual void AutoCalculateStepSizes (const gz::math::Vector3d &_stepSize)=0
 Alters each cascade's step size. The last cascade is set to stepSize. The rest of the cascades are set to step sizes that are >= stepSize automatically. Should be called after adding all cascades. More...
virtual void Bind (const CameraPtr &_camera)=0
 CIVCT relies on having multiple cascades around a central position, typically a camera. This function binds a camera for us to monitor and will act as the center of those cascades. More...
virtual bool ConsistentCascadeSteps () const =0
 Retrieve current setting. See SetConsistentCascadeSteps. More...
virtual DebugVisualizationMode DebugVisualization () const =0
 Returns current visualization mode. More...
virtual bool HighQuality () const =0
 Whether we're using 6 (true) or 4 (false) cones. More...
virtual void LightingChanged ()=0
 Called by Scene when lighting changes so that GI can be updated. More...
virtual void NewSettings (uint32_t _bounceCount, bool _anisotropic)=0
 Sets new settings after having called Init. More...
virtual void PopCascade ()=0
 Removes the last added cascade. More...
virtual void Reset ()=0
 Disables this GI and undoes the internal work performed by Start(). This makes it possible to edit cascades again. More...
virtual void SetConsistentCascadeSteps (bool _consistentCascadeSteps)=0
 Selects how we determine when we need to (partially) rebuild the voxels based on camera movement. More...
virtual void SetDebugVisualization (DebugVisualizationMode _dvm)=0
 Draws the voxels on screen for inspection and understand what is going on with GI. You should be looking at a minecraft-like world. More...
virtual void SetHighQuality (bool _highQuality)=0
 True for high quality (slower). VRAM consumption stays the same. Ogre2 will use 6 cones instead of 4. More...
virtual void SetMaxCascades (const uint32_t _maxCascades)=0
 Tells how many times AddCascade will be called. You can call it fewer times (i.e. some kb of RAM will be wasted) but not more. More...
virtual void Start (uint32_t _bounceCount, bool _anisotropic)=0
 Call this function after adding all cascades. You can no longer add cascades after this. More...
virtual bool Started () const =0
 Returns true if Start() has already been called. Will return false again if Reset() is called. More...
- Public Member Functions inherited from GlobalIlluminationBase
 GlobalIlluminationBase ()
virtual ~GlobalIlluminationBase ()
virtual uint32_t BounceCount () const =0
 Get number of bounces. More...
virtual void Build ()=0
 Build the internal structures required for producing GI This function may take significant time. More...
virtual bool Enabled () const =0
 Returns true if this GI configuration is currently enabled. More...
virtual uint32_t ParticipatingVisuals () const =0
 Visuals that can bounce GI. More...
virtual void SetBounceCount (uint32_t _bounceCount)=0
 Set the number of GI bounces. Very high number can cause a large performance impact. More...
virtual void SetParticipatingVisuals (uint32_t _mask)=0
 Set which visuals can bounce GI. More...
virtual void UpdateCamera ()=0
 Called by Scene on an active GlobalIlluminationBase whenever first rendering happens for a new frame. This implies Build has been called already. More...
virtual void UpdateLighting ()=0
 Called by Scene on an active GlobalIlluminationBase whenever lighting changes. This implies Build has been called already. More...
- Protected Member Functions inherited from GlobalIlluminationBase
 Destroy the class. More...
virtual void Init ()=0
 Initialize the class. More...
 Sets this GI solution as enabled. More...
gz/rendering/GlobalIlluminationCiVct.hh
◆ DebugVisualizationMode
Enumerator
DVM_Albedo
Debug voxelized Albedo.
DVM_Normal
Debug voxelized Normals.
DVM_Emissive
Debug voxelized Emissive materials.
DVM_Lighting
Debug VCT result (i.e. what's used by GI)
DVM_None
Disable debugging.
◆ GlobalIlluminationCiVct()
◆ ~GlobalIlluminationCiVct()
virtual ~GlobalIlluminationCiVct ( )
◆ AddCascade()
virtual CiVctCascadePtr AddCascade ( const CiVctCascade *  _ref)
Adds a new cascade.
Remarks
Cannot be called anymore after Start() has been called
[in]_refCan be nullptr. If you already have a cascade, we will clone its settings.
New Cascade to control its settings.
Implemented in Ogre2GlobalIlluminationCiVct.
◆ Anisotropic()
virtual bool Anisotropic ( ) const
Anisotropy setting
◆ AutoCalculateStepSizes()
virtual void AutoCalculateStepSizes ( const gz::math::Vector3d &  _stepSize)
[in]_stepSizeSee CiVctCascade::SetCameraStepSize
◆ Bind()
virtual void Bind ( const CameraPtr &  _camera)
Remarks
If no camera is bound, the active camera will be used, which can cause performance problems if multiple sensors are present
[in]_cameraCamera to bind. Nullptr to unbind.
◆ ConsistentCascadeSteps()
virtual bool ConsistentCascadeSteps ( ) const
True if the feature is enabled
◆ DebugVisualization()
virtual DebugVisualizationMode DebugVisualization ( ) const
Visualization mode
◆ HighQuality()
virtual bool HighQuality ( ) const
High Quality setting
◆ LightingChanged()
virtual void LightingChanged ( )
◆ NewSettings()
virtual void NewSettings ( uint32_t  _bounceCount,
bool  _anisotropic
[in]_bounceCountSee Start
[in]_anisotropicSee Start
◆ PopCascade()
virtual void PopCascade ( )
Remarks
Do NOT try to call any of the functions of the CiVctCascadePtr returned by AddCascade after this call.
◆ Reset()
virtual void Reset ( )
◆ SetConsistentCascadeSteps()
virtual void SetConsistentCascadeSteps ( bool  _consistentCascadeSteps)
Remarks
If camera movement is deterministic, output is always deterministic regardless of this setting
[in]_consistentCascadeStepsTrue: Results can feel very determnistic because it is predictable.
Camera position is quantized in voxelCellSize * cascade.cameraStepSize. This means the camera position is in a 'cell' or 'grid'.
When the camera position moves onto another grid, we partially revoxelize results.
Advantage: A camera at pos XYZ will always have the same results
Disadvantage: if the camera jumps back and forth between voxels, revoxelizations will trigger frequently causing obvious frequent jumps in brightness
False: Revoxelization happens after the camera has travelled cascade.cameraStepSize cells away from the last point of voxelization.
Advantage: Infrequent revoxelizations. If camera movement is restricted around the last voxelization point, we will never revoxelize.
Disadvantage: Taking a picture at pos XYZ, then going away, and taking another picture at same pos XYZ may not result in the same brightness / image; which can make it feel unpredictable or non-deterministic. This can be workarounded by temporarily setting SetConsistentCascadeSteps(true) then back false after taking the picture
◆ SetDebugVisualization()
virtual void SetDebugVisualization ( DebugVisualizationMode  _dvm)
[in]_dvmWhat component to visualize
◆ SetHighQuality()
virtual void SetHighQuality ( bool  _highQuality)
[in]_highQualityQuality setting
◆ SetMaxCascades()
virtual void SetMaxCascades ( const uint32_t  _maxCascades)
Remarks
You can't call this function after adding cascades The semantics are similar to std::vector::reserve
[in]_maxCascadesNumber of times AddCascade will be called
◆ Start()
virtual void Start ( uint32_t  _bounceCount,
bool  _anisotropic
[in]_bounceCountNumber of bounces for cascade 0. The rest of the cascades are autocalculated to maintain even brightness levels.
Range is [0; inf) but a value of 0 is strongly discouraged if you have more than 1 cascade as you can end up with very uneven brightness levels between cascades For more info see Ogre's VctLighting::update
[in]_anisotropicWhether we should use anisotropic VCT (higher quality, but consumes more VRAM). See GlobalIlluminationVct::SetAnisotropic
◆ Started()
virtual bool Started ( ) const
