Text Class Referenceabstract
#include <gz/rendering/Text>
 Text ()=default
virtual ~Text ()
virtual gz::math::AxisAlignedBox AABB () const =0
virtual float Baseline () const =0
virtual float CharHeight () const =0
virtual gz::math::Color Color () const =0
 Get the text color. More...
virtual std::string FontName () const =0
 Get the font name. More...
virtual TextHorizontalAlign HorizontalAlignment () const =0
virtual void SetBaseline (const float _baseline)=0
virtual void SetCharHeight (const float _height)=0
virtual void SetColor (const gz::math::Color &_color)=0
 Set the text color. More...
virtual void SetFontName (const std::string &_font)=0
 Set the font. More...
virtual void SetShowOnTop (const bool _onTop)=0
 True = text always is displayed on top. More...
virtual void SetSpaceWidth (const float _width)=0
virtual void SetTextAlignment (const TextHorizontalAlign &_hAlign, const TextVerticalAlign &_vAlign)=0
virtual void SetTextString (const std::string &_text)=0
virtual bool ShowOnTop () const =0
virtual float SpaceWidth () const =0
virtual std::string TextString () const =0
virtual TextVerticalAlign VerticalAlignment () const =0
 Clone the geometry. More...
◆ Text()
Text ( )
default
◆ ~Text()
virtual ~Text ( )
◆ AABB()
virtual gz::math::AxisAlignedBox AABB ( ) const
Implemented in OgreText, BaseText< T >, and BaseText< OgreGeometry >.
◆ Baseline()
virtual float Baseline ( ) const
Baseline height
SetBaseline()
Implemented in BaseText< T >, and BaseText< OgreGeometry >.
◆ CharHeight()
virtual float CharHeight ( ) const
SetCharHeight()
◆ Color()
virtual gz::math::Color Color ( ) const
Get the text color.
Text color.
SetColor()
◆ FontName()
virtual std::string FontName ( ) const
Get the font name.
The font name.
SetFontName()
◆ HorizontalAlignment()
virtual TextHorizontalAlign HorizontalAlignment ( ) const
Text horizontal alignment
◆ SetBaseline()
[in]_baselineBaseline height
Baseline()
◆ SetCharHeight()
CharHeight()
◆ SetColor()
virtual void SetColor ( const gz::math::Color &  _color)
Set the text color.
[in]_colorText color.
Color()
◆ SetFontName()
Set the font.
[in]_fontName of the font
FontName()
◆ SetShowOnTop()
ShowOnTop()
◆ SetSpaceWidth()
[in]_widthSpace width
SpaceWidth()
◆ SetTextAlignment()
[in]_vAlignVertical alignment
◆ SetTextString()
[in]_textThe text to display.
Text()
◆ ShowOnTop()
virtual bool ShowOnTop ( ) const
True if it is on top.
SetShowOnTop()
◆ SpaceWidth()
virtual float SpaceWidth ( ) const
Space width
SetSpaceWidth()
◆ TextString()
virtual std::string TextString ( ) const
The displayed text.
SetText()
◆ VerticalAlignment()
virtual TextVerticalAlign VerticalAlignment ( ) const
Text vertical alignment
