Draws a wireframe box. More...
#include <gz/rendering/WireBox>
virtual ~WireBox ()
virtual gz::math::AxisAlignedBox Box () const =0
 Get the wireframe box. More...
virtual void SetBox (const gz::math::AxisAlignedBox &_box)=0
 Set the axis aligned box. More...
 Clone the geometry. More...
 WireBox ()
◆ WireBox()
WireBox ( )
◆ ~WireBox()
virtual ~WireBox ( )
◆ Box()
virtual gz::math::AxisAlignedBox Box ( ) const
The wireframe box.
Implemented in BaseWireBox< T >, BaseWireBox< Ogre2Geometry >, and BaseWireBox< OgreGeometry >.
◆ SetBox()
virtual void SetBox ( const gz::math::AxisAlignedBox &  _box)
[in]_boxThe axis aligned box
