Gazebo Sensors
Manager Class Reference
#include <Manager.hh>
 Manager ()
 constructor
virtual ~Manager ()
 destructor
SensorId AddSensor (std::unique_ptr< Sensor > _sensor)
 Add a sensor for this manager to manage.
template<typename SensorType , typename SdfType >
SensorType * CreateSensor (SdfType _sdf)
 Create a sensor from an SDF object with a known sensor type.
bool Init ()
 Initialize the sensor library without rendering or physics.
bool Remove (const SensorId _id)
 Remove a sensor by ID.
void RunOnce (const std::chrono::steady_clock::duration &_time, bool _force=false)
 Run the sensor generation one step.
Sensor * Sensor (SensorId _id)
 Get an instance of a loaded sensor by sensor id.
This class is responsible for loading and running sensors, and providing sensors with common environments to generate data from.
The primary interface through which to load a sensor is LoadSensor(). This takes an sdf element pointer that should be configured with everything the sensor will need. Custom sensors configuration must be in the <plugin> tag of the sdf::Element. The manager will dynamically load the sensor library and update it.
Remarks
This class is not thread safe.
◆ Manager()
Manager ( )
constructor
◆ ~Manager()
virtual ~Manager ( )
destructor
◆ AddSensor()
SensorId AddSensor ( std::unique_ptr< Sensor >  _sensor)
Sensor()
[in]_sensorPointer to the sensor
A sensor id that refers to the created sensor. NO_SENSOR is returned on error.
◆ CreateSensor()
SensorType * CreateSensor ( SdfType  _sdf)
inline
Sensor()
[in]_sdfAn SDF element or DOM object.
Template Parameters
SensorTypeSensor type
SdfTypeIt may be an sdf::ElementPtr containing a sensor or an sdf::Sensor.
A pointer to the created sensor. Null returned on error. The Manager keeps ownership of the pointer's lifetime.
References Manager::AddSensor(), SensorFactory::CreateSensor(), std::endl(), std::move(), and gz::sensors::NO_SENSOR.
bool Init ( )
True if successfully initialized, false if not
◆ Remove()
bool Remove ( const SensorId  _id)
[in]_idID of the sensor to remove
True if the sensor exists and removed.
◆ RunOnce()
void RunOnce ( const std::chrono::steady_clock::duration &  _time,
bool  _force = false
_timeThe current simulated time
_forceIf true, all sensors are forced to update. Otherwise a sensor will update based on it's Hz rate.
◆ Sensor()
Sensor * Sensor ( SensorId  _id)
[in]_idIdenitifier of the sensor.
Pointer to the sensor, nullptr on error.
