Gazebo Sensors
SegmentationCameraSensor Class Reference
Segmentation camera sensor class. More...
#include <SegmentationCameraSensor.hh>
 SegmentationCameraSensor ()
 constructor
virtual ~SegmentationCameraSensor ()
 destructor
 Set a callback to be called when image frame data is generated.
 Get image height.
 Get image width.
virtual bool Init () override
void OnNewSegmentationFrame (const uint8_t *_data, unsigned int _width, unsigned int _height, unsigned int _channels, const std::string &_format)
 Segmentation data callback used to get the data from the sensor.
rendering::SegmentationCameraPtr SegmentationCamera () const
 Get the rendering segmentation camera.
 Set the rendering scene.
 CameraSensor ()
 constructor
virtual ~CameraSensor ()
 destructor
double Baseline () const
 Get baseline for stereo cameras.
 Check if there are any image subscribers.
 Check if there are any info subscribers.
const std::string & InfoTopic () const
 Topic where camera info is published.
 Get the camera optical frame.
 Get pointer to rendering camera object.
 Set baseline for stereo cameras. This is used to populate the projection matrix in the camera info message.
 Set the camera info topic.
 Update the sensor.
 Set camera lens intrinsics and projection based on values from SDF. If the camera SDF does not contain intrinsic or projection parameters, the camera will not be updated. Instead, the camera SDF will be updated with intrinsic and projection values computed manually from current camera intrinsic properties.
virtual ~RenderingSensor ()
 destructor
void Render ()
 Get the rendering scene.
 destructor
bool EnableMetrics () const
 FrameId.
SensorId Id () const
 Get the sensor's ID.
bool IsActive () const
bool IsTriggered () const
 Get name.
 Get the current pose.
sdf::ElementPtr SDF () const
void SetActive (bool _active)
 Set Frame ID of the sensor.
 Set the parent of the sensor.
 Update the sensor.
double UpdateRate () const
bool AdvertiseInfo ()
 Advertise camera info topic.
 Advertise camera info topic. This version takes a string that allows one to override the camera_info topic.
 Populate camera info message.
 Publish camera info message.
 RenderingSensor ()
 constructor
 Sensor ()
 constructor
This class creates segmentation images from a Gazebo Rendering scene. The scene must be created in advance and given to Manager::Init(). It offers both a gz-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ SegmentationCameraSensor()
constructor
◆ ~SegmentationCameraSensor()
virtual ~SegmentationCameraSensor ( )
destructor
◆ ConnectImageCallback()
gz::common::ConnectionPtr ConnectImageCallback ( std::function< void(const gz::msgs::Image &)>  _callback)
Remarks
◆ HasConnections()
◆ ImageHeight()
Get image height.
height of the image
◆ ImageWidth()
Get image width.
width of the image
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ OnNewSegmentationFrame()
void OnNewSegmentationFrame ( const uint8_t *  _data,
const std::string &  _format
[in]_datapointer to the data from the sensor
[in]_widthwidth of the segmentation image
[in]_heightheight of the segmentation image
[in]_channelsnum of channels
[in]_formatstring with the format
◆ SegmentationCamera()
rendering::SegmentationCameraPtr SegmentationCamera ( ) const
Segmentation camera pointer
◆ SetScene()
[in]_nowThe current time
true if the update was successful
