Gazebo Sensors
ThermalCameraSensor Class Reference
#include <ThermalCameraSensor.hh>
 ThermalCameraSensor ()
 constructor
virtual ~ThermalCameraSensor ()
 destructor
common::ConnectionPtr ConnectImageCallback (std::function< void(const msgs::Image &)> _callback)
 Set a callback to be called when image frame data is generated.
 Get image height.
 Get image width.
virtual bool Init () override
void OnNewThermalFrame (const uint16_t *_scan, unsigned int _width, unsigned int _height, unsigned int _channels, const std::string &_format)
 Thermal data callback used to get the data from the sensor.
virtual void SetAmbientTemperature (float _ambient)
 Set the ambient temperature of the environment.
virtual void SetAmbientTemperatureRange (float _range)
 Set the range of ambient temperature.
virtual void SetLinearResolution (float _resolution)
 Set the temperature linear resolution. The thermal image data returned will be temperature in kelvin / resolution. Typical values are 0.01 (10mK), 0.1 (100mK), or 0.04 to simulate 14 bit format.
virtual void SetMaxTemperature (float _max)
 Set the maximum temperature the sensor can detect.
virtual void SetMinTemperature (float _min)
 Set the minimum temperature the sensor can detect.
 Set the rendering scene.
virtual rendering::ThermalCameraPtr ThermalCamera () const
 Get a pointer to the rendering thermal camera.
 CameraSensor ()
 constructor
virtual ~CameraSensor ()
 destructor
double Baseline () const
 Get baseline for stereo cameras.
 Check if there are any image subscribers.
 Check if there are any info subscribers.
const std::string & InfoTopic () const
 Topic where camera info is published.
 Get the camera optical frame.
 Get pointer to rendering camera object.
 Set baseline for stereo cameras. This is used to populate the projection matrix in the camera info message.
 Set the camera info topic.
 Update the sensor.
 Set camera lens intrinsics and projection based on values from SDF. If the camera SDF does not contain intrinsic or projection parameters, the camera will not be updated. Instead, the camera SDF will be updated with intrinsic and projection values computed manually from current camera intrinsic properties.
virtual ~RenderingSensor ()
 destructor
void Render ()
 Get the rendering scene.
 destructor
bool EnableMetrics () const
 FrameId.
SensorId Id () const
 Get the sensor's ID.
bool IsActive () const
bool IsTriggered () const
 Get name.
 Get the current pose.
sdf::ElementPtr SDF () const
void SetActive (bool _active)
 Set Frame ID of the sensor.
 Set the parent of the sensor.
 Update the sensor.
double UpdateRate () const
bool AdvertiseInfo ()
 Advertise camera info topic.
 Advertise camera info topic. This version takes a string that allows one to override the camera_info topic.
 Populate camera info message.
 Publish camera info message.
 RenderingSensor ()
 constructor
 Sensor ()
 constructor
This class creates thermal image from a Gazebo Rendering scene. The scene must be created in advance and given to Manager::Init(). It offers both a gz-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ ThermalCameraSensor()
constructor
◆ ~ThermalCameraSensor()
virtual ~ThermalCameraSensor ( )
destructor
◆ ConnectImageCallback()
common::ConnectionPtr ConnectImageCallback ( std::function< void(const msgs::Image &)>  _callback)
Remarks
◆ HasConnections()
◆ ImageHeight()
Get image height.
height of the image
◆ ImageWidth()
Get image width.
width of the image
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ OnNewThermalFrame()
void OnNewThermalFrame ( const uint16_t *  _scan,
const std::string &  _format
[in]_scanpointer to the data from the sensor
[in]_widthwidth of the thermal image
[in]_heightheight of the thermal image
[in]_channelsbytes used for the thermal data
[in]_formatstring with the format
◆ SetAmbientTemperature()
virtual void SetAmbientTemperature ( float  _ambient)
[in]_ambientAmbient temperature in kelvin
◆ SetAmbientTemperatureRange()
virtual void SetAmbientTemperatureRange ( float  _range)
[in]_rangeThe ambient temperature ranges from (ambient - range/2) to (ambient + range/2).
◆ SetLinearResolution()
virtual void SetLinearResolution ( float  _resolution)
[in]_resolutionTemperature linear resolution
◆ SetMaxTemperature()
virtual void SetMaxTemperature ( float  _max)
[in]_maxMax temperature in kelvin
◆ SetMinTemperature()
virtual void SetMinTemperature ( float  _min)
[in]_minMin temperature in kelvin
◆ SetScene()
◆ ThermalCamera()
virtual rendering::ThermalCameraPtr ThermalCamera ( ) const
Rendering thermal camera
[in]_nowThe current time
