Gazebo Sensors
WideAngleCameraSensor Class Reference
Wide Angle camera sensor class. More...
#include <WideAngleCameraSensor.hh>
 WideAngleCameraSensor ()
 constructor
virtual ~WideAngleCameraSensor ()
 destructor
common::ConnectionPtr ConnectImageCallback (std::function< void(const msgs::Image &)> _callback)
 Set a callback to be called when image frame data is generated.
 Get image height.
 Get image width.
virtual bool Init () override
void OnNewWideAngleFrame (const unsigned char *_data, unsigned int _width, unsigned int _height, unsigned int _channels, const std::string &_format)
 Image data callback used to get the data from the sensor.
rendering::CameraPtr RenderingCamera () const override
 Get pointer to rendering camera object.
 Set the rendering scene.
virtual rendering::WideAngleCameraPtr WideAngleCamera () const
 Get a pointer to the rendering wide angle camera.
 CameraSensor ()
 constructor
virtual ~CameraSensor ()
 destructor
double Baseline () const
 Get baseline for stereo cameras.
 Check if there are any image subscribers.
 Check if there are any info subscribers.
const std::string & InfoTopic () const
 Topic where camera info is published.
 Get the camera optical frame.
 Set baseline for stereo cameras. This is used to populate the projection matrix in the camera info message.
 Set the camera info topic.
 Update the sensor.
 Set camera lens intrinsics and projection based on values from SDF. If the camera SDF does not contain intrinsic or projection parameters, the camera will not be updated. Instead, the camera SDF will be updated with intrinsic and projection values computed manually from current camera intrinsic properties.
virtual ~RenderingSensor ()
 destructor
void Render ()
 Get the rendering scene.
 destructor
bool EnableMetrics () const
 FrameId.
SensorId Id () const
 Get the sensor's ID.
bool IsActive () const
bool IsTriggered () const
 Get name.
 Get the current pose.
sdf::ElementPtr SDF () const
void SetActive (bool _active)
 Set Frame ID of the sensor.
 Set the parent of the sensor.
 Update the sensor.
double UpdateRate () const
bool AdvertiseInfo ()
 Advertise camera info topic.
 Advertise camera info topic. This version takes a string that allows one to override the camera_info topic.
 Populate camera info message.
 Publish camera info message.
 RenderingSensor ()
 constructor
 Sensor ()
 constructor
This class creates wide angle camera image from a Gazebo Rendering scene. The scene must be created in advance and given to Manager::Init() It offers both a gz-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ WideAngleCameraSensor()
constructor
◆ ~WideAngleCameraSensor()
virtual ~WideAngleCameraSensor ( )
destructor
◆ ConnectImageCallback()
common::ConnectionPtr ConnectImageCallback ( std::function< void(const msgs::Image &)>  _callback)
Remarks
◆ HasConnections()
◆ ImageHeight()
Get image height.
height of the image
◆ ImageWidth()
Get image width.
width of the image
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ OnNewWideAngleFrame()
void OnNewWideAngleFrame ( const unsigned char *  _data,
const std::string &  _format
[in]_datapointer to the data from the sensor
[in]_widthwidth of the image
[in]_heightheight of the image
[in]_channelsbytes used for the image data
[in]_formatstring with the format
◆ RenderingCamera()
rendering::CameraPtr RenderingCamera ( ) const
Camera in Gazebo Rendering.
◆ SetScene()
[in]_nowThe current time
◆ WideAngleCamera()
virtual rendering::WideAngleCameraPtr WideAngleCamera ( ) const
Wide angle camera
