This class provides wrappers around entities and components which are more convenient and straight-forward to use than dealing with the EntityComponentManager directly. All the functions provided here are meant to be used with a actor entity. More...
#include <gz/sim/Actor.hh>
 Actor (sim::Entity _entity=kNullEntity)
std::optional< std::string > AnimationName (const EntityComponentManager &_ecm) const
 Get the name of animation used by the actor.
std::optional< std::chrono::steady_clock::duration > AnimationTime (const EntityComponentManager &_ecm) const
 Get the time of animation for this actor.
sim::Entity Entity () const
 Get the entity which this Actor is related to.
 Get the actor's unscoped name.
std::optional< math::Pose3d > Pose (const EntityComponentManager &_ecm) const
 Get the pose of the actor. If the actor has a trajectory, this will only return the origin pose of the trajectory and not the actual world pose of the actor.
 Reset Entity to a new one.
void SetAnimationName (EntityComponentManager &_ecm, const std::string &_name)
 Set the name of animation to use for this actor.
void SetAnimationTime (EntityComponentManager &_ecm, const std::chrono::steady_clock::duration &_time)
 Set the time of animation for this actor.
void SetTrajectoryPose (EntityComponentManager &_ecm, const math::Pose3d &_pose)
 Set the trajectory pose of the actor. There are two ways that the actor can follow a trajectory: 1) SDF script, 2) manually setting trajectory pose. This function enables option 2). Manually setting the trajectory pose will override the scripted trajectory specified in SDF.
std::optional< math::Pose3d > TrajectoryPose (const EntityComponentManager &_ecm) const
 Get the trajectory pose of the actor. There are two ways that the actor can follow a trajectory: 1) SDF script, 2) manually setting trajectory pose. This function retrieves 2) the manual trajectory pose set by the user. The Trajectory pose is given relative to the trajectory pose origin returned by Pose().
 Check whether this actor correctly refers to an entity that has a components::Actor.
std::optional< math::Pose3d > WorldPose (const EntityComponentManager &_ecm) const
 Get the world pose of the actor. This returns the current world pose of the actor computed by gazebo. The world pose is the combination of the actor's pose and its trajectory pose. The currently trajectory pose is either manually set via SetTrajectoryPose or interpolated from waypoints in the SDF script based on the current time.
For example, given an actor's entity, find the value of its name component, one could use the entity-component manager (ecm) directly as follows:
Actor actor(entity); std::string name = actor.Name(ecm);
◆ Actor()
Actor ( sim::Entity  _entity = kNullEntity)
[in]_entityActor entity
◆ AnimationName()
std::optional< std::string > AnimationName ( const EntityComponentManager &  _ecm) const
Animation name
◆ AnimationTime()
std::optional< std::chrono::steady_clock::duration > AnimationTime ( const EntityComponentManager &  _ecm) const
Animation time
◆ Entity()
sim::Entity Entity ( ) const
Actor entity.
◆ Name()
std::optional< std::string > Name ( const EntityComponentManager &  _ecm) const
Actor's name or nullopt if the entity does not have a components::Name component
◆ Pose()
std::optional< math::Pose3d > Pose ( const EntityComponentManager &  _ecm) const
Pose of the actor or nullopt if the entity does not have a components::Pose component.
WorldPose
◆ ResetEntity()
[in]_newEntityNew actor entity.
◆ SetAnimationName()
void SetAnimationName ( EntityComponentManager &  _ecm,
const std::string &  _name
[in]_ecmEntity Component manager.
[in]_nameAnimation name
◆ SetAnimationTime()
void SetAnimationTime ( EntityComponentManager &  _ecm,
const std::chrono::steady_clock::duration &  _time
[in]_timeAnimation time
◆ SetTrajectoryPose()
void SetTrajectoryPose ( EntityComponentManager &  _ecm,
const math::Pose3d &  _pose
[in]_poseTrajectory pose w.r.t. to the trajectory origin
Pose
◆ TrajectoryPose()
std::optional< math::Pose3d > TrajectoryPose ( const EntityComponentManager &  _ecm) const
Trajectory pose of the actor w.r.t. to trajectory origin.
Pose
◆ Valid()
True if it's a valid actor in the manager.
◆ WorldPose()
std::optional< math::Pose3d > WorldPose ( const EntityComponentManager &  _ecm) const
World pose of the actor or nullopt if the entity does not have a components::WorldPose component.
Pose
