gz::sim::components Namespace Reference
Components represent data, such as position information. An Entity usually has one or more associated components. More...
class  BaseComponent
 Base class for all components. More...
struct  BatteryPowerLoadInfo
 Data structure to hold the consumer power load and the name of the battery it uses. More...
class  Component
 A component type that wraps any data type. The intention is for this class to be used to create simple components while avoiding a lot of boilerplate code. The Identifier must be a unique type so that type aliases can be used to create new components. However the type does not need to be defined anywhere eg. More...
class  Component< NoData, Identifier, Serializer >
class  ComponentDescriptor
 A class for an object responsible for creating components. More...
class  ComponentDescriptorBase
 A base class for an object responsible for creating components. More...
class  ComponentDescriptorQueue
 A class to hold the queue of component descriptors registered by translation units. This queue is necessary to ensure that component creation continues to work after plugins are unloaded. The typical scenario this aims to solve is: More...
struct  DetachableJointInfo
 Data structure to hold information about the parent and child links connected by a detachable joint. More...
struct  EnvironmentalData
 Environment data across time and space. This is useful to introduce physical quantities that may be of interest even if not modelled in simulation. More...
class  Factory
 A factory that generates a component based on a string type. More...
struct  RaycastDataInfo
 A struct that holds the raycasting data, including ray and results. More...
struct  RaycastResultInfo
 A struct that holds the result of a raycasting operation. More...
struct  RayInfo
 A struct that holds the information of a ray. More...
struct  RegistrationObjectId
 A wrapper around uintptr_t to prevent implicit conversions. More...
struct  TemperatureRangeInfo
 Data structure to hold a temperature range, in kelvin. More...
using Actor = Component< sdf::Actor, class ActorTag, serializers::ActorSerializer >
 This component contains actor source information. For more information on actors, see SDF's Actor element.
using Actuators = Component< msgs::Actuators, class ActuatorsTag, serializers::MsgSerializer >
 A component type that contains a msgs::Actuators message. This is used for example, to communicate between the MulticopterMotorModel and MulticopterVelocityControl systems.
using AirPressureSensor = Component< sdf::Sensor, class AirPressureSensorTag, serializers::SensorSerializer >
 A component type that contains an air pressure sensor, sdf::AirPressure, information.
using AirSpeedSensor = Component< sdf::Sensor, class AirSpeedSensorTag, serializers::SensorSerializer >
 A component type that contains an air speed sensor, sdf::AirSpeed, information.
using Altimeter = Component< sdf::Sensor, class AltimeterTag, serializers::SensorSerializer >
 A component type that contains an altimeter sensor, sdf::Altimeter, information.
using AngularAcceleration = Component< math::Vector3d, class AngularAccelerationTag >
 A component type that contains angular acceleration of an entity represented by gz::math::Vector3d.
using AngularVelocity = Component< math::Vector3d, class AngularVelocityTag >
 A component type that contains angular velocity of an entity represented by gz::math::Vector3d.
using AngularVelocityCmd = Component< math::Vector3d, class AngularVelocityCmdTag >
 A component type that contains the commanded angular velocity of an entity, in its own frame, represented by gz::math::Vector3d.
using AngularVelocityReset = Component< math::Vector3d, class AngularVelocityResetTag >
 Angular velocity of an entity, in its own frame and in SI units (rad/s). The angular velocity is.
using Atmosphere = Component< sdf::Atmosphere, class AtmosphereTag, serializers::AtmosphereSerializer >
 This component holds atmosphere properties of the world.
using AxisAlignedBox = Component< gz::math::AxisAlignedBox, class AxisAlignedBoxTag, serializers::AxisAlignedBoxSerializer >
 A component type that contains axis aligned box, gz::math::AxisAlignedBox, information. The axis aligned box is created from collisions in the entity.
using BatteryPowerLoad = Component< BatteryPowerLoadInfo, class BatteryPowerLoadTag >
 A component that indicates the total consumption of a battery.
using BatterySoC = Component< float, class BatterySoCTag >
using BoundingBoxCamera = Component< sdf::Sensor, class BoundingBoxCameraTag, serializers::SensorSerializer >
 A component type that contains a BoundingBox camera sensor, sdf::Camera, information.
using Camera = Component< sdf::Sensor, class CameraTag, serializers::SensorSerializer >
 A component type that contains a camera sensor, sdf::Camera, information.
using CanonicalLink = Component< NoData, class CanonicalLinkTag >
 A component that identifies an entity as being a canonical link.
using CastShadows = Component< bool, class CastShadowsTag >
 A component used to indicate that an entity casts shadows e.g. visual entities.
using CenterOfVolume = Component< math::Vector3d, class CenterOfVolumeTag >
 A component for an entity's center of volume. Units are in meters. The Vector3 value indicates center of volume of an entity. The position of the center of volume is relative to the pose of the parent entity, which is usually a link.
using ChildLinkName = Component< std::string, class ChildLinkNameTag, serializers::StringSerializer >
 A component used to indicate that a model is childlinkname (i.e. not moveable).
using CollideBitmaskCmd = Component< uint16_t, class CollideBitmaskCmdTag >
 A component that contains a uint16_t command to change the collide bitmask of an entity.
using Collision = Component< NoData, class CollisionTag >
 A component that identifies an entity as being a collision.
using ContactSensor = Component< sdf::ElementPtr, class ContactSensorTag >
 TODO(anyone) Substitute with sdf::Contact once that exists? This is currently the whole <sensor> element.
using ContactSensorData = Component< msgs::Contacts, class ContactSensorDataTag, serializers::MsgSerializer >
 A component type that contains a list of contacts.
using CpuLidar = Component< sdf::Sensor, class CpuLidarTag, serializers::SensorSerializer >
 A component type that contains a CPU lidar sensor, sdf::Sensor, information.
using CustomSensor = Component< sdf::Sensor, class CustomSensorTag, serializers::SensorSerializer >
 A component type that contains a custom sensor's information. A custom sensor is any sensor that's not officially supported through the SDF spec.
using DepthCamera = Component< sdf::Sensor, class DepthCameraTag, serializers::SensorSerializer >
 A component type that contains a depth camera sensor, sdf::Camera, information.
using DetachableJoint = Component< DetachableJointInfo, class DetachableJointTag, serializers::DetachableJointInfoSerializer >
 A component that identifies an entity as being a detachable joint. It also contains additional information about the joint.
using Environment = Component< std::shared_ptr< EnvironmentalData >, class EnvironmentalDataTag >
 A component type that contains a environment data. Ownership is shared to avoid data copies unless necessary.
using ExternalWorldWrenchCmd = Component< msgs::Wrench, class ExternalWorldWrenchCmdTag, serializers::MsgSerializer >
 A component type that contains the external wrench to be applied on an entity expressed in the world frame and represented by gz::msgs::Wrench. Currently this is used for applying wrenches on links. Although the msg::Wrench type has a force_offset member, the value is currently ignored. Instead, the force is applied at the link origin. The wrench uses SI units (N for force and N⋅m for torque).
using ForceTorque = Component< sdf::Sensor, class ForceTorqueTag, serializers::SensorSerializer >
 A component type that contains an FT sensor, sdf::ForceTorque, information.
using Geometry = Component< sdf::Geometry, class GeometryTag, serializers::GeometrySerializer >
 This component holds an entity's geometry.
using GpuLidar = Component< sdf::Sensor, class GpuLidarTag, serializers::SensorSerializer >
 A component type that contains a GPU Lidar sensor, sdf::Lidar, information.
using Gravity = Component< math::Vector3d, class GravityTag >
 Store the gravity acceleration.
using HaltMotion = Component< bool, class HaltMotionTag >
 A component used to turn off a model's joint's movement.
using Imu = Component< sdf::Sensor, class ImuTag, serializers::SensorSerializer >
 A component type that contains an IMU sensor, sdf::IMU, information.
using Inertial = Component< math::Inertiald, class InertialTag, serializers::InertialSerializer >
 This component holds an entity's inertial.
using Joint = Component< NoData, class JointTag >
 A component that identifies an entity as being a joint.
using JointAxis = Component< sdf::JointAxis, class JointAxisTag, serializers::JointAxisSerializer >
 A component that contains the joint axis . This is a simple wrapper around sdf::JointAxis.
using JointEffortLimitsCmd = Component< std::vector< gz::math::Vector2d >, class JointEffortLimitsCmdTag, serializers::VectorSerializer< gz::math::Vector2d > >
 Command for setting effort limits of a joint. Data are a vector with a Vector2 for each DOF. The X() component of the Vector2 specifies the minimum effort limit, the Y() component stands for maximum limit. Set to +-infinity to disable the limits.
using JointForce = Component< std::vector< double >, class JointForceTag, serializers::VectorDoubleSerializer >
 Force applied to a joint in SI units (Nm for revolute, N for prismatic).
using JointForceCmd = Component< std::vector< double >, class JointForceCmdTag >
 Commanded joint forces (or torques) to be applied to a joint in SI units (Nm for revolute, N for prismatic). The component wraps a std::vector and systems that set this component need to ensure that the vector has the same size as the degrees of freedom of the joint.
using JointPosition = Component< std::vector< double >, class JointPositionTag, serializers::VectorDoubleSerializer >
 Joint positions in SI units (rad for revolute, m for prismatic). The component wraps a std::vector of size equal to the degrees of freedom of the joint.
using JointPositionLimitsCmd = Component< std::vector< gz::math::Vector2d >, class JointPositionLimitsCmdTag, serializers::VectorSerializer< gz::math::Vector2d > >
 Command for setting position limits of a joint. Data are a vector with a Vector2 for each DOF. The X() component of the Vector2 specifies the minimum positional limit, the Y() component stands for maximum limit. Set to +-infinity to disable the limits.
using JointPositionReset = Component< std::vector< double >, class JointPositionResetTag, serializers::VectorDoubleSerializer >
using JointTransmittedWrench = Component< msgs::Wrench, class JointTransmittedWrenchTag, serializers::MsgSerializer >
 Joint Transmitted wrench in SI units (Nm for torque, N for force). The wrench is expressed in the Joint frame and the force component is applied at the joint origin.
using JointType = Component< sdf::JointType, class JointTypeTag, serializers::JointTypeSerializer >
 A component that contains the joint type. This is a simple wrapper around sdf::JointType.
using JointVelocity = Component< std::vector< double >, class JointVelocityTag, serializers::VectorDoubleSerializer >
 Base class which can be extended to add serialization.
using JointVelocityCmd = Component< std::vector< double >, class JointVelocityCmdTag, serializers::VectorDoubleSerializer >
using JointVelocityLimitsCmd = Component< std::vector< gz::math::Vector2d >, class JointVelocityLimitsCmdTag, serializers::VectorSerializer< gz::math::Vector2d > >
 Command for setting velocity limits of a joint. Data are a vector with a Vector2 for each DOF. The X() component of the Vector2 specifies the minimum velocity limit, the Y() component stands for maximum limit. Set to +-infinity to disable the limits.
using JointVelocityReset = Component< std::vector< double >, class JointVelocityResetTag, serializers::VectorDoubleSerializer >
 Joint velocities in SI units (rad/s for revolute, m/s for prismatic).
using Kinematic = Component< bool, class KinematicTag >
 A component used to indicate that a link is kinematic. A kinematic link does not react to forces, e.g. gravity or contacts with dynamic links; it only moves as commanded by pose or velocity commands set on the link or on the joint that connects it.
using LaserRetro = Component< double, class LaserRetroTag >
 A component used to indicate an lidar reflective value.
using Level = Component< NoData, class LevelTag >
 This component identifies an entity as being a level.
using LevelBuffer = Component< double, class LevelBufferTag >
 A component that holds the buffer setting of a level's geometry.
using LevelEntityNames = Component< std::set< std::string >, class LevelEntityNamesTag, serializers::LevelEntityNamesSerializer >
 A component that holds a list of names of entities to be loaded in a level.
using Lidar = Component< sdf::Sensor, class LidarTag, serializers::SensorSerializer >
 A component type that contains a Lidar sensor, sdf::Lidar, information.
using Light = Component< sdf::Light, class LightTag, serializers::LightSerializer >
 This component contains light source information. For more information on lights, see SDF's Light element.
using LightCmd = Component< gz::msgs::Light, class LightCmdTag, serializers::MsgSerializer >
 A component type that contains commanded light of an entity in the world frame represented by msgs::Light.
using LightType = Component< std::string, class LightTypeTag, serializers::StringSerializer >
 A component that contains the light type. This is a simple wrapper around std::string.
using LinearAcceleration = Component< math::Vector3d, class LinearAccelerationTag >
 A component type that contains linear acceleration of an entity represented by gz::math::Vector3d.
using LinearVelocity = Component< math::Vector3d, class LinearVelocityTag >
 A component type that contains linear velocity of an entity represented by gz::math::Vector3d.
using LinearVelocityCmd = Component< math::Vector3d, class LinearVelocityCmdTag >
using LinearVelocityReset = Component< math::Vector3d, class LinearVelocityResetTag >
 Linear velocity of an entity in its own frame and in SI units (m/s). The linear velocity is represented by gz::math::Vector3d.
using LinearVelocitySeed = Component< math::Vector3d, class LinearVelocitySeedTag >
 A component type that contains linear velocity seed of an entity expressed in the local frame of the entity and represented by gz::math::Vector3d. This seed can used to generate linear velocities by applying transformations and adding noise.
using Link = Component< NoData, class LinkTag >
 A component that identifies an entity as being a link.
using LogicalAudioSource = Component< logical_audio::Source, class LogicalAudioSourceTag, serializers::LogicalAudioSourceSerializer >
 A component that contains a logical audio source, which is represented by logical_audio::Source.
using LogicalAudioSourcePlayInfo = Component< logical_audio::SourcePlayInfo, class LogicalAudioSourcePlayInfoTag, serializers::LogicalAudioSourcePlayInfoSerializer >
 A component that contains a logical audio source's playing information, which is represented by logical_audio::SourcePlayInfo.
using LogicalCamera = Component< sdf::ElementPtr, class LogicalCameraTag >
 TODO(anyone) Substitute with sdf::LogicalCamera once that exists? This is currently the whole <sensor> element.
using LogicalMicrophone = Component< logical_audio::Microphone, class LogicalMicrophoneTag, serializers::LogicalMicrophoneSerializer >
 A component that contains a logical microphone, which is represented by logical_audio::Microphone.
using LogPlaybackStatistics = Component< gz::msgs::LogPlaybackStatistics, class LogPlaybackStatisticsTag, serializers::MsgSerializer >
 A component type that contains log playback, systems::LogPlayback, information. The log playback is created from world entity upon the playback plugin being loaded.
using MagneticField = Component< math::Vector3d, class MagneticFieldTag >
 Stores the 3D magnetic field in teslas.
using Magnetometer = Component< sdf::Sensor, class MagnetometerTag, serializers::SensorSerializer >
 A component type that contains a magnetometer sensor, sdf::Magnetometer, information.
using Material = Component< sdf::Material, class MaterialTag, serializers::MaterialSerializer >
 This component holds an entity's material.
using Model = Component< NoData, class ModelTag >
 A component that identifies an entity as being a model.
using Name = Component< std::string, class NameTag, serializers::StringSerializer >
 This component holds an entity's name. The component has no concept of scoped names nor does it care about uniqueness.
using NavSat = Component< sdf::Sensor, class NavSatTag, serializers::SensorSerializer >
 A component type that contains an NavSat sensor, sdf::NavSat, information.
using NoData = std::add_lvalue_reference< void >
 Convenient type to be used by components that don't wrap any data. I.e. they act as tags and their presence is enough to infer something about the entity.
using ParentEntity = Component< Entity, class ParentEntityTag >
 This component holds an entity's parent entity.
using ParentLinkName = Component< std::string, class ParentLinkNameTag, serializers::StringSerializer >
 Holds the name of the entity's parent link.
using ParticleEmitter = Component< msgs::ParticleEmitter, class ParticleEmitterTag, serializers::MsgSerializer >
 A component that contains a particle emitter.
using Performer = Component< NoData, class PerformerTag >
 This component identifies an entity as being a performer.
using PerformerAffinity = Component< std::string, class PerformerAffinityTag, serializers::StringSerializer >
 This component holds the address of the distributed secondary that this performer is associated with.
using PerformerLevels = Component< std::set< Entity >, class PerformerLevelsTag, serializers::PerformerLevelsSerializer >
 Holds all the levels which a performer is in.
using Physics = Component< sdf::Physics, class PhysicsTag, serializers::PhysicsSerializer >
 A component type that contains the physics properties of the World entity.
using PhysicsCmd = Component< msgs::Physics, class PhysicsCmdTag >
using PhysicsEnginePlugin = Component< std::string, class PhysicsEnginePluginTag, serializers::StringSerializer >
 Holds the physics engine shared library.
using Pose = Component< gz::math::Pose3d, class PoseTag >
 A component type that contains pose, gz::math::Pose3d, information.
using Projector = Component< sdf::Projector, class ProjectorTag, serializers::ProjectorSerializer >
 A component type that contains a projector, sdf::Projector, information.
using RaycastData = Component< RaycastDataInfo, class RaycastDataTag, serializers::DefaultSerializer< RaycastDataInfo > >
 A component type that contains the rays traced from an entity into a physics world, along with the results of the raycasting operation.
using Recreate = Component< NoData, class RecreateTag >
 A component that identifies an entity needs to be recreated. Currently, only Models will be processed for recreation by the SimulationRunner in the ProcessRecreateEntitiesRemove and ProcessRecreateEntitiesCreate functions.
using RenderEngineGuiPlugin = Component< std::string, class RenderEngineGuiPluginTag, serializers::StringSerializer >
 Holds the render engine gui shared library.
using RenderEngineServerApiBackend = Component< std::string, class RenderEngineServerApiBackendTag, serializers::StringSerializer >
 Holds the render engine server API backend name.
using RenderEngineServerHeadless = Component< bool, class RenderEngineServerHeadlessTag >
 Holds the headless mode.
using RenderEngineServerPlugin = Component< std::string, class RenderEngineServerPluginTag, serializers::StringSerializer >
 Holds the render engine server shared library.
using RgbdCamera = Component< sdf::Sensor, class RgbdCameraTag, serializers::SensorSerializer >
 A component type that contains a RGBD camera sensor, sdf::Camera, information.
using Scene = Component< sdf::Scene, class SceneTag, serializers::SceneSerializer >
 This component holds scene properties of the world.
using SegmentationCamera = Component< sdf::Sensor, class SegmentationCameraTag, serializers::SensorSerializer >
 A component type that contains a Segmentation camera sensor, sdf::Camera, information.
using SelfCollide = Component< bool, class SelfCollideTag >
 A component used to hold a model's self collide property.
using SemanticCategory = Component< uint8_t, class SemanticCategoryTag >
 A component that holds the semantic category of an entity. This is meant to be used by systems such as EntitySemantics to assign categories to entities. See https://github.com/ros-simulation/simulation_interfaces/blob/1.0.0/msg/EntityCategory.msg.
using SemanticLabel = Component< uint32_t, class SemanticLabelTag >
 A component that holds the label of an entity. One example use case of the Label component is with Segmentation & Bounding box sensors to generate dataset annotations.
using Sensor = Component< NoData, class SensorTag >
using SlipComplianceCmd = Component< std::vector< double >, class SlipComplianceCmdTag >
 A component type that contains the slip compliance parameters to be set on a collision. The 0 and 1 index values correspond to the slip compliance parameters in friction direction 1 (fdir1) and friction direction 2 (fdir2) respectively.
using SourceFilePath = Component< std::string, class SourceFilePathTag, serializers::StringSerializer >
 This component holds the filepath to the source from which an entity is created. For example, it can be used to store the file path of a model's SDFormat file.
using SphericalCoordinates = Component< math::SphericalCoordinates, class SphericalCoordinatesTag, serializers::SphericalCoordinatesSerializer >
 This component holds the spherical coordinates of the world origin.
using Static = Component< bool, class StaticTag >
 A component used to indicate that a model is static (i.e. not moveable).
using SystemPluginInfo = Component< msgs::Plugin_V, class SystemPluginInfoTag, serializers::MsgSerializer >
 This component holds information about all the system plugins that are attached to an entity. The content of each system is populated the moment the plugin is instantiated and isn't modified throughout simulation.
using Temperature = Component< math::Temperature, class TemperatureTag >
 A component that stores temperature data in Kelvin.
using TemperatureRange = Component< TemperatureRangeInfo, class TemperatureRangeTag, serializers::TemperatureRangeInfoSerializer >
 A component that stores a temperature range in kelvin.
using ThermalCamera = Component< sdf::Sensor, class ThermalCameraTag, serializers::SensorSerializer >
 A component type that contains a Thermal camera sensor, sdf::Sensor, information.
using ThreadPitch = Component< double, class ThreadPitchTag >
 A component used to store the thread pitch of a screw joint.
using Transparency = Component< float, class TransparencyTag >
 A component used to indicate an entity's transparency value e.g. visual entities. Value is in the range from 0 (opaque) to 1 (transparent).
using VisibilityFlags = Component< uint32_t, class VisibilityFlagsTag >
 This component holds an entity's visibility flags (visual entities)
using Visual = Component< NoData, class VisualTag >
 A component that identifies an entity as being a visual.
using VisualCmd = Component< gz::msgs::Visual, class VisualCmdTag, serializers::MsgSerializer >
 A component type that contains commanded visual of an entity in the world frame represented by msgs::Visual.
using Volume = Component< double, class VolumeTag >
 A volume component where the units are m^3. Double value indicates volume of an entity.
using WheelSlipCmd = Component< gz::msgs::WheelSlipParametersCmd, class WheelSlipCmdTag, serializers::MsgSerializer >
 A component type that contains commanded wheel slip parameters of an entity in the world frame represented by msgs::WheelSlipParameters.
using WideAngleCamera = Component< sdf::Sensor, class WideAngleCameraTag, serializers::SensorSerializer >
 A component type that contains a wide angle camera sensor, sdf::Camera, information.
using Wind = Component< NoData, class WindTag >
 A component that identifies an entity as being a wind.
using WindMode = Component< bool, class WindModeTag >
 A component used to indicate whether an entity is affected by wind.
using World = Component< NoData, class WorldTag >
 A component that identifies an entity as being a world.
using WorldPoseCmd = Component< math::Pose3d, class WorldPoseCmdTag >
 A component type that contains commanded pose of an entity in the world frame represented by gz::math::Pose3d.
using WrenchMeasured = Component< msgs::Wrench, class WrenchMeasuredTag, serializers::MsgSerializer >
 Wrench measured by a ForceTorqueSensor in SI units (Nm for torque, N for force). The wrench is expressed in the Sensor frame and the force component is applied at the sensor origin.
Functions
 GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.Actor", Actor) using AnimationTime
 GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.AnimationTime", AnimationTime) using AnimationName
 Name of animation being currently played.
 GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.CanonicalLink", CanonicalLink) using ModelCanonicalLink
 A component that contains a reference to the canonical link entity of a model.
 GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.CollideBitmaskCmd", CollideBitmaskCmd) using CategoryBitmaskCmd
 A component that contains a uint16_t command to change the category bitmask of an entity.
 GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.Collision", Collision) using CollisionElement
 A component that holds the sdf::Collision object.
 GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.CollisionElement", CollisionElement) using EnableContactSurfaceCustomization
 A component used to enable customization of contact surface for a collision. The customization itself is done in callback of event CollectContactSurfaceProperties from PhysicsEvents.
 GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.CollisionEnabled", CollisionEnabled) using CollisionEnabledCmd
 A component that contains a bool command to change the collision state of an entity.
 GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.EnableContactSurfaceCustomization", EnableContactSurfaceCustomization) using CollisionEnabled
 Store the collision enabled flag.
 GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.GravityEnabled", GravityEnabled) using GravityEnabledCmd
 Store the gravity enabled CMD.
 GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.Kinematic", Kinematic) using KinematicCmd
 A component that contains a bool command to change the kinematic state of a link. Requires a physics engine that supports the KinematicLink feature, e.g. bullet-featherstone.
 GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.Level", Level) using DefaultLevel
 This component identifies an entity as being a default level.
 GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.Model", Model) using ModelSdf
 A component that holds the model's SDF DOM.
 GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.Performer", Performer) using PerformerRef
 This component contains the performer reference name.
 GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.PhysicsCollisionDetector", PhysicsCollisionDetector) using PhysicsSolver
 The name of the solver to be used. The supported options will depend on the physics engine being used.
 GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.PhysicsSolver", PhysicsSolver) using PhysicsSolverIterations
 The number of solver iterations for each step.
 GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.RaycastData", RaycastData) using NeedsRaycast
 Tag component that requests the physics system to perform raycasting for this entity on the current step. Set by sensor systems in PreUpdate, cleared by the physics system after the raycast is performed.
 GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.Sensor", Sensor) using SensorTopic
 Name of the transport topic where a sensor is publishing its data. For sensors that publish on more than one topic, this will usually be the prefix common to all topics of that sensor.
 GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.Static", Static) using StaticCmd
 A component that contains a bool command to change the static state of an entity.
 GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.VisibilityFlags", VisibilityFlags) using VisibilityMask
 This component holds an entity's visibility mask (camera sensor entities)
 GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.Visual", Visual) using VisualPlugin
 A component that contains a visual plugin's SDF element.
 GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.World", World) using WorldSdf
 A component that holds the world's SDF DOM.
 GZ_SIM_REGISTER_COMPONENT ("gz_sim_components.WorldPose", WorldPose) using TrajectoryPose
 A component type that contains pose, gz::math::Pose3d, information within a trajectory.
The set of Components assigned to an Entity also act as a key. Systems process Entities based on their key. For example, a physics system may process only entities that have pose and inertia components.
Typedef Documentation
◆ Actor
using Actor = Component<sdf::Actor, class ActorTag, serializers::ActorSerializer>
◆ Actuators
using Actuators = Component<msgs::Actuators, class ActuatorsTag, serializers::MsgSerializer>
◆ AirPressureSensor
using AirPressureSensor = Component<sdf::Sensor, class AirPressureSensorTag, serializers::SensorSerializer>
◆ AirSpeedSensor
using AirSpeedSensor = Component<sdf::Sensor, class AirSpeedSensorTag, serializers::SensorSerializer>
◆ Altimeter
using Altimeter = Component<sdf::Sensor, class AltimeterTag, serializers::SensorSerializer>
◆ AngularAcceleration
using AngularAcceleration = Component<math::Vector3d, class AngularAccelerationTag>
◆ AngularVelocity
using AngularVelocity = Component<math::Vector3d, class AngularVelocityTag>
◆ AngularVelocityCmd
using AngularVelocityCmd = Component<math::Vector3d, class AngularVelocityCmdTag>
◆ AngularVelocityReset
using AngularVelocityReset = Component<math::Vector3d, class AngularVelocityResetTag>
◆ Atmosphere
using Atmosphere = Component<sdf::Atmosphere, class AtmosphereTag, serializers::AtmosphereSerializer>
◆ AxisAlignedBox
◆ BatteryPowerLoad
using BatteryPowerLoad = Component<BatteryPowerLoadInfo, class BatteryPowerLoadTag>
◆ BatterySoC
using BatterySoC = Component<float, class BatterySoCTag>
A component that identifies an entity as being a battery. Float value indicates state of charge.
◆ BoundingBoxCamera
using BoundingBoxCamera = Component<sdf::Sensor, class BoundingBoxCameraTag, serializers::SensorSerializer>
◆ Camera
using Camera = Component<sdf::Sensor, class CameraTag, serializers::SensorSerializer>
◆ CanonicalLink
using CanonicalLink = Component<NoData, class CanonicalLinkTag>
◆ CastShadows
using CastShadows = Component<bool, class CastShadowsTag>
◆ CenterOfVolume
using CenterOfVolume = Component<math::Vector3d, class CenterOfVolumeTag>
◆ ChildLinkName
◆ CollideBitmaskCmd
using CollideBitmaskCmd = Component<uint16_t, class CollideBitmaskCmdTag>
◆ Collision
using Collision = Component<NoData, class CollisionTag>
◆ ContactSensor
using ContactSensor = Component<sdf::ElementPtr, class ContactSensorTag>
◆ ContactSensorData
using ContactSensorData = Component<msgs::Contacts, class ContactSensorDataTag, serializers::MsgSerializer>
◆ CpuLidar
using CpuLidar = Component<sdf::Sensor, class CpuLidarTag, serializers::SensorSerializer>
◆ CustomSensor
using CustomSensor = Component<sdf::Sensor, class CustomSensorTag, serializers::SensorSerializer>
◆ DepthCamera
using DepthCamera = Component<sdf::Sensor, class DepthCameraTag, serializers::SensorSerializer>
◆ DetachableJoint
◆ Environment
using Environment = Component<std::shared_ptr<EnvironmentalData>, class EnvironmentalDataTag>
◆ ExternalWorldWrenchCmd
using ExternalWorldWrenchCmd = Component<msgs::Wrench, class ExternalWorldWrenchCmdTag, serializers::MsgSerializer>
◆ ForceTorque
using ForceTorque = Component<sdf::Sensor, class ForceTorqueTag, serializers::SensorSerializer>
◆ Geometry
using Geometry = Component<sdf::Geometry, class GeometryTag, serializers::GeometrySerializer>
◆ GpuLidar
using GpuLidar = Component<sdf::Sensor, class GpuLidarTag, serializers::SensorSerializer>
◆ Gravity
using Gravity = Component<math::Vector3d, class GravityTag>
◆ HaltMotion
using HaltMotion = Component<bool, class HaltMotionTag>
◆ Imu
using Imu = Component<sdf::Sensor, class ImuTag, serializers::SensorSerializer>
◆ Inertial
◆ Joint
using Joint = Component<NoData, class JointTag>
◆ JointAxis
using JointAxis = Component<sdf::JointAxis, class JointAxisTag, serializers::JointAxisSerializer>
◆ JointEffortLimitsCmd
Note
It is expected that the physics plugin reads this component and sets the limit to the dynamics engine. After setting it, the data of this component will be cleared (i.e. the vector will have length zero).
◆ JointForce
using JointForce = Component<std::vector<double>, class JointForceTag, serializers::VectorDoubleSerializer>
◆ JointForceCmd
using JointForceCmd = Component<std::vector<double>, class JointForceCmdTag>
◆ JointPosition
using JointPosition = Component<std::vector<double>, class JointPositionTag, serializers::VectorDoubleSerializer>
◆ JointPositionLimitsCmd
Note
◆ JointPositionReset
using JointPositionReset = Component<std::vector<double>, class JointPositionResetTag, serializers::VectorDoubleSerializer>
◆ JointTransmittedWrench
using JointTransmittedWrench = Component<msgs::Wrench, class JointTransmittedWrenchTag, serializers::MsgSerializer>
Note
The term Wrench is used here to mean a pair of 3D vectors representing torque and force quantities expressed in a given frame and where the force is applied at the origin of the frame. This is different from the Wrench used in screw theory.
The value of force_offset in msgs::Wrench is ignored for this component. The force is assumed to be applied at the origin of the joint frame.
◆ JointType
using JointType = Component<sdf::JointType, class JointTypeTag, serializers::JointTypeSerializer>
◆ JointVelocity
using JointVelocity = Component<std::vector<double>, class JointVelocityTag, serializers::VectorDoubleSerializer>
◆ JointVelocityCmd
using JointVelocityCmd = Component<std::vector<double>, class JointVelocityCmdTag, serializers::VectorDoubleSerializer>
◆ JointVelocityLimitsCmd
Note
◆ JointVelocityReset
using JointVelocityReset = Component<std::vector<double>, class JointVelocityResetTag, serializers::VectorDoubleSerializer>
◆ Kinematic
using Kinematic = Component<bool, class KinematicTag>
◆ LaserRetro
using LaserRetro = Component<double, class LaserRetroTag>
◆ Level
using Level = Component<NoData, class LevelTag>
◆ LevelBuffer
using LevelBuffer = Component<double, class LevelBufferTag>
◆ LevelEntityNames
◆ Lidar
using Lidar = Component<sdf::Sensor, class LidarTag, serializers::SensorSerializer>
◆ Light
using Light = Component<sdf::Light, class LightTag, serializers::LightSerializer>
◆ LightCmd
using LightCmd = Component<gz::msgs::Light, class LightCmdTag, serializers::MsgSerializer>
◆ LightType
◆ LinearAcceleration
using LinearAcceleration = Component<math::Vector3d, class LinearAccelerationTag>
◆ LinearVelocity
using LinearVelocity = Component<math::Vector3d, class LinearVelocityTag>
◆ LinearVelocityCmd
using LinearVelocityCmd = Component< math::Vector3d, class LinearVelocityCmdTag>
entity represented by gz::math::Vector3d, expressed in the entity's frame.
◆ LinearVelocityReset
using LinearVelocityReset = Component<math::Vector3d , class LinearVelocityResetTag>
◆ LinearVelocitySeed
using LinearVelocitySeed = Component<math::Vector3d, class LinearVelocitySeedTag>
◆ Link
using Link = Component<NoData, class LinkTag>
◆ LogicalAudioSource
◆ LogicalAudioSourcePlayInfo
◆ LogicalCamera
using LogicalCamera = Component<sdf::ElementPtr, class LogicalCameraTag>
◆ LogicalMicrophone
◆ LogPlaybackStatistics
using LogPlaybackStatistics = Component<gz::msgs::LogPlaybackStatistics, class LogPlaybackStatisticsTag, serializers::MsgSerializer>
◆ MagneticField
using MagneticField = Component<math::Vector3d, class MagneticFieldTag>
◆ Magnetometer
using Magnetometer = Component<sdf::Sensor, class MagnetometerTag, serializers::SensorSerializer>
◆ Material
using Material = Component<sdf::Material, class MaterialTag, serializers::MaterialSerializer>
◆ Model
using Model = Component<NoData, class ModelTag>
◆ Name
◆ NavSat
using NavSat = Component<sdf::Sensor, class NavSatTag, serializers::SensorSerializer>
◆ NoData
◆ ParentEntity
using ParentEntity = Component<Entity, class ParentEntityTag>
Note that the EntityComponentManager also keeps the parent-child relationship stored in a graph, and that information should be kept in sync with the parent entity components. Therefore, it is recommended that the ParentEntity component is never edited by hand, and instead, entities should be created using the sim::SdfEntityCreator class.
◆ ParentLinkName
◆ ParticleEmitter
using ParticleEmitter = Component<msgs::ParticleEmitter, class ParticleEmitterTag, serializers::MsgSerializer>
◆ Performer
using Performer = Component<NoData, class PerformerTag>
◆ PerformerAffinity
◆ PerformerLevels
◆ Physics
using Physics = Component<sdf::Physics, class PhysicsTag, serializers::PhysicsSerializer>
◆ PhysicsCmd
using PhysicsCmd = Component<msgs::Physics, class PhysicsCmdTag>
◆ PhysicsEnginePlugin
◆ Pose
using Pose = Component<gz::math::Pose3d, class PoseTag>
◆ Projector
using Projector = Component<sdf::Projector, class ProjectorTag, serializers::ProjectorSerializer>
◆ RaycastData
This component is primarily used for applications that require raycasting. The target application defines the rays, and the physics system plugin updates the raycasting results during each update loop.
◆ Recreate
using Recreate = Component<NoData, class RecreateTag>
The GUI ModelEditor contains example code on how to use this component. For example, the ModelEditor allows a user to add a link to an existing model. The existing model is tagged with this component so that it can be recreated by the server.
◆ RenderEngineGuiPlugin
using RenderEngineGuiPlugin = Component<std::string, class RenderEngineGuiPluginTag, serializers::StringSerializer>
◆ RenderEngineServerApiBackend
using RenderEngineServerApiBackend = Component<std::string, class RenderEngineServerApiBackendTag, serializers::StringSerializer>
◆ RenderEngineServerHeadless
using RenderEngineServerHeadless = Component<bool, class RenderEngineServerHeadlessTag>
◆ RenderEngineServerPlugin
using RenderEngineServerPlugin = Component<std::string, class RenderEngineServerPluginTag, serializers::StringSerializer>
◆ RgbdCamera
using RgbdCamera = Component<sdf::Sensor, class RgbdCameraTag, serializers::SensorSerializer>
◆ Scene
using Scene = Component<sdf::Scene, class SceneTag, serializers::SceneSerializer>
◆ SegmentationCamera
using SegmentationCamera = Component<sdf::Sensor, class SegmentationCameraTag, serializers::SensorSerializer>
◆ SelfCollide
using SelfCollide = Component<bool, class SelfCollideTag>
◆ SemanticCategory
using SemanticCategory = Component<uint8_t, class SemanticCategoryTag>
◆ SemanticLabel
using SemanticLabel = Component<uint32_t, class SemanticLabelTag>
◆ Sensor
using Sensor = Component<NoData, class SensorTag>
◆ SlipComplianceCmd
using SlipComplianceCmd = Component<std::vector<double>, class SlipComplianceCmdTag>
◆ SourceFilePath
◆ SphericalCoordinates
◆ Static
using Static = Component<bool, class StaticTag>
◆ SystemPluginInfo
using SystemPluginInfo = Component<msgs::Plugin_V, class SystemPluginInfoTag, serializers::MsgSerializer>
◆ Temperature
using Temperature = Component<math::Temperature, class TemperatureTag>
◆ TemperatureRange
◆ ThermalCamera
using ThermalCamera = Component<sdf::Sensor, class ThermalCameraTag, serializers::SensorSerializer>
◆ ThreadPitch
using ThreadPitch = Component<double, class ThreadPitchTag>
◆ Transparency
using Transparency = Component<float, class TransparencyTag>
◆ VisibilityFlags
using VisibilityFlags = Component<uint32_t, class VisibilityFlagsTag>
◆ Visual
using Visual = Component<NoData, class VisualTag>
◆ VisualCmd
using VisualCmd = Component<gz::msgs::Visual, class VisualCmdTag, serializers::MsgSerializer>
◆ Volume
using Volume = Component<double, class VolumeTag>
◆ WheelSlipCmd
using WheelSlipCmd = Component<gz::msgs::WheelSlipParametersCmd, class WheelSlipCmdTag, serializers::MsgSerializer>
◆ WideAngleCamera
using WideAngleCamera = Component<sdf::Sensor, class WideAngleCameraTag, serializers::SensorSerializer>
◆ Wind
using Wind = Component<NoData, class WindTag>
◆ WindMode
using WindMode = Component<bool, class WindModeTag>
◆ World
using World = Component<NoData, class WorldTag>
◆ WorldPoseCmd
using WorldPoseCmd = Component<math::Pose3d, class WorldPoseCmdTag>
◆ WrenchMeasured
using WrenchMeasured = Component<msgs::Wrench, class WrenchMeasuredTag, serializers::MsgSerializer>
Note
The value of force_offset in msgs::Wrench is ignored for this component. The force is assumed to be applied at the origin of the sensor frame.
Function Documentation
◆ GZ_SIM_REGISTER_COMPONENT() [1/22]
GZ_SIM_REGISTER_COMPONENT ( "gz_sim_components.Actor"  ,
Actor
Initial value:
Component<math::Vector3d, class WorldAngularAccelerationTag>
A component that stores temperature linear resolution in Kelvin.
A component type that contains pose, gz::math::Pose3d, information in world frame.
The name of the collision detector to be used. The supported options will depend on the physics engine being used.
A component that contains a particle emitter command.
A component type that contains linear velocity seed of an entity in the world frame represented by gz::math::Vector3d. This seed can used to generate linear velocities by applying transformations and adding noise.
Linear velocity of an entity in the world frame and in SI units (m/s). The linear velocity is represented by gz::math::Vector3d.
A component type that contains the commanded linear velocity of an entity represented by gz::math::Vector3d, expressed in the world frame.
A component type that contains linear velocity of an entity in the world frame represented by gz::math::Vector3d.
A component type that contains linear acceleration of an entity in the world frame represented by gz::math::Vector3d.
A component that contains the second joint axis for joints with two axes. This is a simple wrapper around sdf::JointAxis.
Store the gravity enabled flag.
A component that overrides the global enforce_fixed_constraint policy for a specific detachable joint.
Angular velocity of an entity in the world frame and in SI units (rad/s). The angular velocity is.
A component type that contains the commanded angular velocity of an entity in the world frame represented by gz::math::Vector3d.
A component type that contains angular velocity of an entity in the world frame represented by gz::math::Vector3d.
A component type that contains angular acceleration of an entity in the world frame represented by gz::math::Vector3d.
◆ GZ_SIM_REGISTER_COMPONENT() [2/22]
GZ_SIM_REGISTER_COMPONENT ( "gz_sim_components.AnimationTime"  ,
AnimationTime
◆ GZ_SIM_REGISTER_COMPONENT() [3/22]
GZ_SIM_REGISTER_COMPONENT ( "gz_sim_components.CanonicalLink"  ,
CanonicalLink
◆ GZ_SIM_REGISTER_COMPONENT() [4/22]
GZ_SIM_REGISTER_COMPONENT ( "gz_sim_components.CollideBitmaskCmd"  ,
CollideBitmaskCmd
◆ GZ_SIM_REGISTER_COMPONENT() [5/22]
GZ_SIM_REGISTER_COMPONENT ( "gz_sim_components.Collision"  ,
Collision
◆ GZ_SIM_REGISTER_COMPONENT() [6/22]
GZ_SIM_REGISTER_COMPONENT ( "gz_sim_components.CollisionElement"  ,
CollisionElement
◆ GZ_SIM_REGISTER_COMPONENT() [7/22]
GZ_SIM_REGISTER_COMPONENT ( "gz_sim_components.CollisionEnabled"  ,
CollisionEnabled
◆ GZ_SIM_REGISTER_COMPONENT() [8/22]
GZ_SIM_REGISTER_COMPONENT ( "gz_sim_components.EnableContactSurfaceCustomization"  ,
◆ GZ_SIM_REGISTER_COMPONENT() [9/22]
GZ_SIM_REGISTER_COMPONENT ( "gz_sim_components.GravityEnabled"  ,
GravityEnabled
◆ GZ_SIM_REGISTER_COMPONENT() [10/22]
GZ_SIM_REGISTER_COMPONENT ( "gz_sim_components.Kinematic"  ,
Kinematic
◆ GZ_SIM_REGISTER_COMPONENT() [11/22]
GZ_SIM_REGISTER_COMPONENT ( "gz_sim_components.Level"  ,
Level
◆ GZ_SIM_REGISTER_COMPONENT() [12/22]
GZ_SIM_REGISTER_COMPONENT ( "gz_sim_components.Model"  ,
Model
◆ GZ_SIM_REGISTER_COMPONENT() [13/22]
GZ_SIM_REGISTER_COMPONENT ( "gz_sim_components.Performer"  ,
Performer
◆ GZ_SIM_REGISTER_COMPONENT() [14/22]
GZ_SIM_REGISTER_COMPONENT ( "gz_sim_components.PhysicsCollisionDetector"  ,
◆ GZ_SIM_REGISTER_COMPONENT() [15/22]
GZ_SIM_REGISTER_COMPONENT ( "gz_sim_components.PhysicsSolver"  ,
PhysicsSolver
◆ GZ_SIM_REGISTER_COMPONENT() [16/22]
GZ_SIM_REGISTER_COMPONENT ( "gz_sim_components.RaycastData"  ,
RaycastData
◆ GZ_SIM_REGISTER_COMPONENT() [17/22]
GZ_SIM_REGISTER_COMPONENT ( "gz_sim_components.Sensor"  ,
Sensor
◆ GZ_SIM_REGISTER_COMPONENT() [18/22]
GZ_SIM_REGISTER_COMPONENT ( "gz_sim_components.Static"  ,
Static
◆ GZ_SIM_REGISTER_COMPONENT() [19/22]
GZ_SIM_REGISTER_COMPONENT ( "gz_sim_components.VisibilityFlags"  ,
VisibilityFlags
◆ GZ_SIM_REGISTER_COMPONENT() [20/22]
GZ_SIM_REGISTER_COMPONENT ( "gz_sim_components.Visual"  ,
Visual
◆ GZ_SIM_REGISTER_COMPONENT() [21/22]
GZ_SIM_REGISTER_COMPONENT ( "gz_sim_components.World"  ,
World
◆ GZ_SIM_REGISTER_COMPONENT() [22/22]
GZ_SIM_REGISTER_COMPONENT ( "gz_sim_components.WorldPose"  ,
WorldPose
