Sensor Class Reference
This class provides wrappers around entities and components which are more convenient and straight-forward to use than dealing with the EntityComponentManager directly. All the functions provided here are meant to be used with a sensor entity. More...
#include <gz/sim/Sensor.hh>
 Sensor (sim::Entity _entity=kNullEntity)
sim::Entity Entity () const
 Get the entity which this Sensor is related to.
 Get the sensor's unscoped name.
std::optional< sim::Entity > Parent (const EntityComponentManager &_ecm) const
 Get the parent entity. This can be a link or a joint.
std::optional< math::Pose3d > Pose (const EntityComponentManager &_ecm) const
 Get the pose of the sensor.
 Reset Entity to a new one.
std::optional< std::string > Topic (const EntityComponentManager &_ecm) const
 Get the topic of the sensor.
 Check whether this sensor correctly refers to an entity that has a components::Sensor.
For example, given a sensor's entity, find the value of its name component, one could use the entity-component manager (ecm) directly as follows:
Sensor sensor(entity); std::string name = sensor.Name(ecm);
◆ Sensor()
Sensor ( sim::Entity  _entity = kNullEntity)
[in]_entitySensor entity
◆ Entity()
sim::Entity Entity ( ) const
Sensor entity.
◆ Name()
std::optional< std::string > Name ( const EntityComponentManager &  _ecm) const
Sensor's name or nullopt if the entity does not have a components::Name component
◆ Parent()
std::optional< sim::Entity > Parent ( const EntityComponentManager &  _ecm) const
Parent entity or nullopt if the entity does not have a components::ParentEntity component.
◆ Pose()
std::optional< math::Pose3d > Pose ( const EntityComponentManager &  _ecm) const
Pose of the sensor or nullopt if the entity does not have a components::Pose component.
◆ ResetEntity()
[in]_newEntityNew sensor entity.
◆ Topic()
std::optional< std::string > Topic ( const EntityComponentManager &  _ecm) const
Topic of the sensor or nullopt if the entity does not have a components::SensorTopic component.
◆ Valid()
True if it's a valid sensor in the manager.
