A factory that generates a component based on a string type. More...
#include <Factory.hh>
 Factory (const Factory &)=delete
 Factory (Factory &)=delete
bool HasType (ComponentTypeId _typeId)
 Check if a component type has been registered. return True if registered.
std::string Name (ComponentTypeId _typeId) const
 Get a component's type name given its type ID. return Unique component name.
template<typename ComponentTypeT >
std::unique_ptr< ComponentTypeT > New ()
 Create a new instance of a component.
std::unique_ptr< components::BaseComponent > New (const ComponentTypeId &_type)
std::unique_ptr< components::BaseComponent > New (const ComponentTypeId &_type, const components::BaseComponent *_data)
 Create a new instance of a component, initialized with particular data.
void operator= (const Factory &)=delete
void operator= (Factory &&)=delete
void Register (const char *_type, ComponentDescriptorBase *_compDesc, RegistrationObjectId _regObjId)
 Register a component so that the factory can create instances of the component based on an ID.
std::vector< ComponentTypeId > TypeIds () const
 Get all the registered component types by ID. return Vector of component IDs.
void Unregister (ComponentTypeId _typeId, RegistrationObjectId _regObjId)
 Unregister a component so that the factory can't create instances of the component anymore.
void Unregister (RegistrationObjectId _regObjId)
static Factory * Instance ()
 Get an instance of the singleton.
Public Attributes
std::map< ComponentTypeId, std::string > namesById
 A list of IDs and their equivalent names.
std::map< ComponentTypeId, std::string > runtimeNamesById
 Keep track of the runtime names for types and warn the user if they try to register different types with the same typeName.
◆ Factory() [1/2]
Factory ( Factory &  )
delete
◆ Factory() [2/2]
Factory ( const Factory &  )
delete
◆ HasType()
bool HasType ( ComponentTypeId  _typeId)
inline
◆ Instance()
static Factory * Instance ( )
static
◆ Name()
std::string Name ( ComponentTypeId  _typeId) const
inline
References map< K, T >::at(), string::end(), map< K, T >::find(), and Factory::namesById.
◆ New() [1/3]
std::unique_ptr< ComponentTypeT > New ( )
inline
Pointer to a component. Null if the component type could not be handled.
Template Parameters
ComponentTypeTcomponent type requested
References Factory::New().
Referenced by Factory::New().
◆ New() [2/3]
std::unique_ptr< components::BaseComponent > New ( const ComponentTypeId &  _type)
inline
[in]_typeComponent id to create.
◆ New() [3/3]
std::unique_ptr< components::BaseComponent > New ( const ComponentTypeId &  _type,
const components::BaseComponent *  _data
inline
[in]_dataThe data to populate the component instance with.
References std::endl(), gzerr, and BaseComponent::TypeId().
◆ operator=() [1/2]
void operator= ( const Factory &  )
delete
◆ operator=() [2/2]
void operator= ( Factory &&  )
delete
◆ Register()
void Register ( const char *  _type,
ComponentDescriptorBase *  _compDesc,
inline
[in]_typeType of component to register.
[in]_compDescObject to manage the creation of ComponentTypeT objects.
[in]_regObjIdAn ID that identifies the registration object. This is generally derived from the this pointer of the static component registration object created when calling GZ_SIM_REGISTER_COMPONENT.
Template Parameters
ComponentTypeTType of component to register.
References map< K, T >::end(), std::endl(), gz::common::env(), map< K, T >::find(), gz::common::hash64(), Factory::namesById, and Factory::runtimeNamesById.
◆ TypeIds()
std::vector< ComponentTypeId > TypeIds ( ) const
inline
References vector< T >::push_back().
◆ Unregister() [1/2]
void Unregister ( ComponentTypeId  _typeId,
inline
This function will not reset the typeId static variable within the component type itself. Prefer using the templated Unregister function when possible.
[in]_typeIdType of component to unregister.
◆ Unregister() [2/2]
void Unregister ( RegistrationObjectId  _regObjId)
inline
Template Parameters
ComponentTypeTType of component to unregister.
References Factory::Unregister().
Referenced by Factory::Unregister().
◆ namesById
Referenced by Factory::Name(), and Factory::Register().
◆ runtimeNamesById
std::map<ComponentTypeId, std::string> runtimeNamesById
Referenced by Factory::Register().
