LogPlayback Class Reference
Log state playback. More...
#include <gz/sim/systems/log/LogPlayback.hh>
 LogPlayback ()
 ~LogPlayback () override
void Configure (const Entity &_id, const std::shared_ptr< const sdf::Element > &_sdf, EntityComponentManager &_ecm, EventManager &_eventMgr) final
 Documentation inherited.
- Public Member Functions inherited from ISystemReset
virtual ~ISystemReset ()=default
- Public Member Functions inherited from ISystemUpdate
virtual ~ISystemUpdate ()=default
Log state playback.
◆ LogPlayback()
LogPlayback ( )
◆ ~LogPlayback()
~LogPlayback ( )
void Configure ( const Entity &  _id,
finalvirtual
◆ Reset()
finalvirtual
Implements ISystemReset.
finalvirtual
Implements ISystemUpdate.
