gz::sim::systems Namespace Reference
Namespace for all System plugins. Refer to the System class for more information about systems. More...
namespace  actions
namespace  events
namespace  guards
namespace  hydrodynamics
namespace  multicopter_control
namespace  optical_tactile_sensor
namespace  physics_system
class  AckermannSteering
 Ackermann steering controller which can be attached to a model with any number of left and right wheels. More...
class  AcousticComms
 A comms model that simulates communication using acoustic devices. The model uses simple distance based acoustics model. More...
class  AdvancedLiftDrag
 The LiftDrag system computes lift and drag forces enabling simulation of aerodynamic robots. More...
class  AirPressure
 An air pressure sensor that reports vertical position and velocity readings over gz transport. More...
class  AirSpeed
 An air speed sensor that reports vertical position and velocity readings over gz transport. More...
class  Altimeter
 An altimeter sensor that reports vertical position and velocity readings over gz transport. More...
class  ApplyJointForce
 This system applies a force to the first axis of a specified joint. More...
class  ApplyLinkWrench
 Exposes transport topics and SDF params for applying forces and torques to links in simulation. It should be attached to a world. More...
class  Breadcrumbs
 A system for creating Breadcrumbs in the form of models that can get deployed/spawned at the location of the model to which this system is attached. Each breadcrumb is a complete sdf::Model. When deployed, the pose of the breadcrumb model is offset from the containing model by the pose specified in the <pose> element of the breadcrumb model. A name is generated for the breadcrumb by appending the current count of deployments to the name specified in the breadcrumb <model> element. The model specified in the <breadcrumb> parameter serves as a template for deploying multiple breadcrumbs of the same type. Including models from Fuel is accomplished by creating a <model> that includes the Fuel model using the <include> tag. See the example in examples/worlds/breadcrumbs.sdf. More...
class  Buoyancy
 A system that simulates buoyancy of objects immersed in fluid. All SDF parameters are optional. This system must be attached to the world and this system will apply buoyancy to all links that have collision shapes. More...
class  BuoyancyEnginePlugin
 This class provides a simple mechanical bladder which is used to control the buoyancy of an underwater glider. It uses Archimedes' principle to apply an upward force based on the volume of the bladder. It listens to the topic buoyancy_engine or /model/{namespace}/buoyancy_engine topic for the volume of the bladder in cubicmeters. More...
class  CameraVideoRecorder
 Record video from a camera sensor. More...
class  ColladaWorldExporter
 A plugin that exports a world to a mesh. When loaded the plugin will dump a mesh containing all the models in the world to the current directory. More...
class  CommsEndpoint
 A system that registers in the comms broker an endpoint. You're creating an address attached to the model where the plugin is running. The system will bind this address in the broker automatically for you and unbind it when the model is destroyed. More...
class  Contact
 Contact sensor system which manages all contact sensors in simulation. More...
class  CpuLidar
 This system manages all CPU-based lidar sensors in simulation. Each sensor publishes lidar scan data over Gazebo Transport. More...
class  DetachableJoint
 A system that initially attaches two models via a fixed joint and allows for the models to get detached during simulation via a topic. A model can be re-attached during simulation via a topic. The status of the detached state can be monitored via a topic as well. More...
class  DiffDrive
 Differential drive controller which can be attached to a model with any number of left and right wheels. More...
class  DoorTimer
 Timer that's used to keep a door open. It has a configurable default wait duration that when exceeded, it calls a function to let the state machine know to transition to the next state. The timer also checks whether the doorway is blocked, in which case it keeps the door open until whatever blocks the doorway moves out of the way. More...
class  DopplerVelocityLogSystem
 System that creates and updates DopplerVelocityLog (DVL) sensors. More...
class  Elevator
 System that controls an elevator. It closely models the structure and functionality of a real elevator. It individually controls the cabin and doors of the elevator, queues commands for the elevator and stops at intermediate floors if a command is received while the last one is ongoing, and keeps a door open if the doorway is blocked. The model of the elevator can have arbitrarily many floor levels and at arbitrary heights each. More...
class  ElevatorStateMachineDef
 Elevator state machine frontend. Defines the transition table and initial state of the state machine. More...
class  ElevatorStateMachinePrivate
class  EnvironmentPreload
 A plugin to preload an Environment component into the ECM upon simulation start-up. More...
class  FollowActor
 Make an actor follow a target entity in the world. More...
class  ForceTorque
 This system manages all Force-Torque sensors in simulation. Each FT sensor reports readings over Gazebo Transport. More...
class  FreeSpaceExplorer
 This plugin is to be used with a model that has a 2D LiDAR attached to it. It uses this 2d lidar to export an occupancy map of the world. More...
class  Hydrodynamics
 Hydrodynamic damping and current forces for underwater vehicles. More...
class  Imu
 This system manages all IMU sensors in simulation. Each IMU sensor eports vertical position, angular velocity and lienar acceleration readings over Gazebo Transport. More...
class  JointController
 Joint controller which can be attached to a model with a reference to a single joint. Currently only the first axis of a joint is actuated. More...
class  JointMonitor
 Monitor that checks the state of a joint. When the joint reaches the configured target, it calls a function to let the state machine know to transition to the next state. More...
class  JointPositionController
 Joint position controller which can be attached to a model with a reference to a single joint. More...
class  JointStatePublisher
 The JointStatePublisher system publishes joint state information for a model. The published message type is gz::msgs::Model, and the publication topic is determined by the <topic> parameter. More...
class  JointTrajectoryController
 Joint trajectory controller, which can be attached to a model with reference to one or more 1-axis joints in order to follow a trajectory. More...
class  KineticEnergyMonitor
 A system that monitors the kinetic energy of a link in a model and publishes when there is a lost of kinetic energy during a timestep that surpasses a specific threshold. This system can be used to detect when a model could be damaged. More...
class  Label
 A label plugin that annotates models by setting the label for the parent entity's visuals. The plugin can be attached to models, visuals, or actors. More...
class  LensFlare
 Add lens flare effects to the camera output as a render pass. More...
class  LiftDrag
class  LighterThanAirDynamics
 This class provides the effect of viscousity on the hull of lighter-than-air vehicles such as airships. The equations implemented is based on the work published in [1], which describes a modeling approach for the nonlinear dynamics simulation of airships and [2] providing more insight of the modelling of an airship. More...
class  LinearBatteryPlugin
 A plugin for simulating battery usage. More...
class  LogicalAudioSensorPlugin
 A plugin for logical audio detection. More...
class  LogicalCamera
 A logical camera sensor that reports objects detected within its frustum readings over gz transport. More...
class  LogPlayback
 Log state playback. More...
class  LogRecord
 Log state recorder. More...
class  LogVideoRecorder
 System which recordings videos from log playback There are two ways to specify what entities in the log playback to follow and record videos for: 1) by entity name and 2) by region. See the system parameters. More...
class  LookupWheelSlip
 Lookup Wheel Slip system. This plugin dynamically adjusts the wheel slip and friction parameters based on the wheel's position on the region covered by the specified lookup image map (slip map) where slip and friction values are encoded in the image's RGB channels. This plugin needs to be used together with the WheelSlip system. LookupWheelSlip system params: More...
class  Magnetometer
 An magnetometer sensor that reports the magnetic field in its current location. More...
class  MecanumDrive
 Mecanum drive controller which can be attached to a model with any number of front/back left/right wheels. More...
class  ModelPhotoShoot
 This plugin is a port of the old ModelPropShop plugin from gazebo classic. It generates 5 pictures of a model: perspective, top, front, side and back. It can do it using the default position or moving the joint to random positions. It allows saving the camera and joint poses so it can be replicated in other systems. More...
class  MulticopterMotorModel
 This system applies a thrust force to models with spinning propellers. See examples/worlds/quadcopter.sdf for a demonstration. More...
class  MulticopterVelocityControl
 This is a velocity controller for multicopters that allows control over the linear velocity and the yaw angular velocity of the vehicle. The velocities are expressed in the body frame of the vehicle. A vehicle with at least 4 rotors is required for the controller to function. More...
class  NavSat
 System that handles navigation satellite sensors, such as GPS, that reports position and velocity in spherical coordinates (latitude / longitude) over Gazebo Transport. More...
class  OdometryPublisher
 Odometry Publisher which can be attached to any entity in order to periodically publish 2D or 3D odometry data in the form of gz::msgs::Odometry messages. More...
class  OpticalTactilePlugin
 Plugin that implements an optical tactile sensor. More...
class  ParticleEmitter
 A system for running and managing particle emitters. A particle emitter is defined using the <particle_emitter> SDF element. More...
class  PerfectComms
 An example of a comms model. This model always delivers any message to its destination. More...
class  PerformerDetector
 A system system that publishes on a topic when a performer enters or leaves a specified region. More...
class  Physics
 Base class for a System. More...
class  PosePublisher
 Pose publisher system. Attach to an entity to publish the transform of its child entities in the form of gz::msgs::Pose messages, or a single gz::msgs::Pose_V message if "use_pose_vector_msg" is true. More...
class  PythonSystemLoader
 Allows systems to be written in Python. More...
class  RFComms
 A comms model that simulates communication using radio frequency (RF) devices. The model uses a log-distance path loss function. More...
class  SceneBroadcaster
 System which periodically publishes a gz::msgs::Scene message with updated information. More...
class  Sensors
 A system that manages sensors. More...
class  ShaderParam
 A plugin for setting shaders to a visual and its params. More...
class  SpacecraftThrusterModel
 This system applies a thrust force to models with RCS-like thrusters. See tutorials/spacecraft_thrusters.md for a tutorial usage. Below follow the minimum necessary parameters needed by the plugin: More...
class  Thermal
 A thermal plugin that sets the temperature for the parent entity. More...
class  ThermalSensor
 A thermal sensor plugin for configuring thermal sensor properties. More...
class  Thruster
 This plugin simulates a maritime thruster for boats and underwater vehicles. It uses the equations described in Fossen's "Guidance and Control of Ocean Vehicles" in page 246. This plugin has two modes of operation. In the default mode it takes in a force in Newtons and applies it to the thruster. It also calculates the theoretical angular velocity of the blades and spins them accordingly. Alternatively, one may send angular velocity commands to calculate the force to be applied using the said equation. In the default mode the plugin will publish angular velocity in radians per second on /model/{ns}/joint/{joint_name}/ang_vel as a gz.msgs.double. If <use_angvel_cmd> is set to true it publishes force in Newtons instead to /model/{ns}/joint/{joint_name}/force. More...
class  TimelinePublisher
 Publishes messages and calls services at fixed points in simulation time, optionally looping. It plays a scripted sequence, such as joint position targets or velocity commands, without an external script. Keyframes follow simulation time, so pausing or stepping the simulation also pauses or steps the timeline, and the timeline starts over when the world is reset or the simulation time goes back. The timeline starts on the first unpaused step after the system is loaded, so a model spawned during the simulation starts its timeline when it appears. More...
class  TouchPlugin
 Plugin which publishes a message if the model it is attached to has touched one or more specified targets continuously during a given time. More...
class  TrackController
 Controller of a track on either a conveyor belt or a tracked vehicle. The system should be attached to a model. If implementing a tracked vehicle, use also TrackedVehicle system. More...
class  TrackedVehicle
 Tracked vehicle controller which can be attached to a model with any number of left and right tracks. The system should be attached to a model. Each track has to have a TrackController system configured and running. More...
class  TrajectoryFollower
 A plugin that scripts the movement of a model based on waypoints. Note that at this point, the trajectory is always in 2D (x, y). The plugin applies a torque until the model is aligned with the next waypoint. Then, it applies a force until the model is close enough to the waypoint. More...
class  TriggeredPublisher
 The triggered publisher system publishes a user specified message on an output topic in response to an input message that matches user specified criteria. It can also call a user specified service as an output in response to an input message. It currently supports blocking service call. An optional simulation time delay can be used delay message publication. More...
class  UserCommands
 This system provides a Gazebo Transport interface to execute commands while simulation is running. More...
class  VelocityControl
 Linear and angular velocity controller which is directly set on a model. More...
class  WebsocketServer
class  WheelSlip
 A system that updates wheel slip parameters based on linear wheel spin velocity (radius * spin rate). More...
class  WindEffects
 A system that simulates a simple wind model. The groundtruth wind information is published on the topic "/world/{world_name}/wind_info". The wind is described as a uniform worldwide model. Its components are computed separately: More...
using ElevatorStateMachine = ::afsm::state_machine< ElevatorStateMachineDef >
 Elevator state machine backend.
Variables
constexpr System::PriorityType kPhysicsPriority = -64
 Default priority value for the Physics system, with a negative value ensuring that it will run before systems with priority System::kDefaultPriority.
constexpr System::PriorityType kPostPhysicsSensorPriority = -32
 A suggested priority value for sensor systems that should execute after the Physics system but before the systems with priority System::kDefaultPriority.
constexpr System::PriorityType kPrePhysicsPriority = -128
 A suggested priority value for a system that should execute before the Physics system.
constexpr System::PriorityType kUserCommandsPriority = -16384
 Default priority value for the UserCommands system, with a very negative value to indicate that it should run before most systems in order to modify the ECM in response to user commands received over gz-transport. This is especially important for user commands that add objects to the world.
Define constant priority values for specific systems.
Typedef Documentation
◆ ElevatorStateMachine
using ElevatorStateMachine = ::afsm::state_machine<ElevatorStateMachineDef>
Variable Documentation
◆ kPhysicsPriority
constexpr
◆ kPostPhysicsSensorPriority
constexpr
◆ kPrePhysicsPriority
constexpr
◆ kUserCommandsPriority
constexpr
