JointMonitor Class Reference
Monitor that checks the state of a joint. When the joint reaches the configured target, it calls a function to let the state machine know to transition to the next state. More...
#include <JointMonitor.hh>
 JointMonitor ()
 ~JointMonitor ()
void Configure (Entity _joint, double _target, double _posEps, double _velEps, const std::function< void()> &_jointTargetReachedCallback)
 Starts monitoring of the position and velocity of the given joint.
void Update (const EntityComponentManager &_ecm)
 Checks whether the position and velocity of the joint are within the configured tolerances.
◆ JointMonitor()
◆ ~JointMonitor()
void Configure ( Entity  _joint,
double  _target,
double  _posEps,
double  _velEps,
const std::function< void()> &  _jointTargetReachedCallback
[in]_jointJoint to monitor
[in]_targetLast joint target (command)
[in]_posEpsPosition tolerance
[in]_velEpsVelocity tolerance
[in]_jointTargetReachedCallbackFunction to call when the joint reaches its target
void Update ( const EntityComponentManager &  _ecm)
