MulticopterMotorModel Class Reference
This system applies a thrust force to models with spinning propellers. See examples/worlds/quadcopter.sdf for a demonstration. More...
#include <MulticopterMotorModel.hh>
 MulticopterMotorModel ()
 ~MulticopterMotorModel () override=default
 Configure the system.
◆ MulticopterMotorModel()
◆ ~MulticopterMotorModel()
~MulticopterMotorModel ( )
overridedefault
