RFComms Class Reference
A comms model that simulates communication using radio frequency (RF) devices. The model uses a log-distance path loss function. More...
#include <RFComms.hh>
 RFComms ()
 ~RFComms () override=default
 This method is called when the system is being configured override this to load any additional params for the comms model.
 This method is called when there is a timestep in the simulator override this to update your data structures as needed.
 ICommsModel ()
 Configure the system.
 This method is called when there is a timestep in the simulator.
This communication model has been ported from: https://github.com/osrf/subt .
This system can be configured with the following SDF parameters:
Optional parameters:
  • <range_config>: Element used to capture the range configuration based on a log-normal distribution. This block can contain any of the next parameters:
    • <max_range>: Hard limit on range (meters). No communication will happen beyond this range. Default is 50.
    • <fading_exponent>: Fading exponent used in the normal distribution. Default is 2.5.
    • <l0>: Path loss at the reference distance (1 meter) in dBm. Default is 40.
    • <sigma>: Standard deviation of the normal distribution. Default is 10.
  • <radio_config>: Element used to capture the radio configuration. This block can contain any of the next parameters:
    • <capacity>: Capacity of radio in bits-per-second. Default is 54000000 (54 Mbps).
    • <tx_power>: Transmitter power in dBm. Default is 27dBm (500mW).
    • <noise_floor>: Noise floor in dBm. Default is -90dBm.
    • <modulation>: Supported modulations: ["QPSK"]. Default is "QPSK".
Example
Here's an example:
filename="gz-sim-rf-comms-system"
name="systems::RFComms">
<range_config>
<max_range>500000.0</max_range>
<fading_exponent>1.5</fading_exponent>
<l0>40</l0>
<sigma>10.0</sigma>
</range_config>
<radio_config>
<capacity>1000000</capacity>
<tx_power>20</tx_power>
<noise_floor>-90</noise_floor>
<modulation>QPSK</modulation>
</radio_config>
◆ RFComms()
RFComms ( )
◆ ~RFComms()
~RFComms ( )
overridedefault
◆ Load()
Implements ICommsModel.
◆ Step()
[in]_ecm- Gazebo Sim's ECM.
