ICommsModel Class Referenceabstract
Abstract interface to define how the environment should handle communication simulation. As an example, this class could be responsible for handling dropouts, decay and packet collisions. More...
#include <ICommsModel.hh>
 ICommsModel ()
 Configure the system.
virtual void Load (const Entity &_entity, std::shared_ptr< const sdf::Element > _sdf, EntityComponentManager &_ecm, EventManager &_eventMgr)=0
 This method is called when the system is being configured override this to load any additional params for the comms model.
virtual void Step (const UpdateInfo &_info, const Registry &_currentRegistry, Registry &_newRegistry, EntityComponentManager &_ecm)=0
 This method is called when there is a timestep in the simulator override this to update your data structures as needed.
 This method is called when there is a timestep in the simulator.
The derived comms models can be configured with the following SDF parameters:
  • Optional parameters: <step_size> If defined this will allow the comms model to run at a higher frequency than the physics engine. This is useful when dealing with ranging. If the <step_size> is set larger than the physics engine dt then the comms model step size will default to dt. Note: for consistency it is advised that the dt is a multiple of timestep. Units are in seconds.
Here's an example:
<physics name="1ms" type="ignored">
<max_step_size>2</max_step_size>
<real_time_factor>1.0</real_time_factor>
</physics>
filename="gz-sim-perfect-comms-system"
name="systems::PerfectComms">
<step_size>1</step_size>
◆ ICommsModel()
ICommsModel ( )
◆ Load()
virtual void Load ( const Entity &  _entity,
Implemented in AcousticComms, PerfectComms, and RFComms.
◆ Step()
virtual void Step ( const UpdateInfo &  _info,
const Registry &  _currentRegistry,
Registry &  _newRegistry,
[in]_ecm- Gazebo Sim's ECM.
◆ StepImpl()
virtual void StepImpl ( const UpdateInfo &  _info,
[in]_infoSimulator information about the current timestep. will become the new registry.
