SpacecraftThrusterModel Class Reference
This system applies a thrust force to models with RCS-like thrusters. See tutorials/spacecraft_thrusters.md for a tutorial usage. Below follow the minimum necessary parameters needed by the plugin: More...
#include <SpacecraftThrusterModel.hh>
 SpacecraftThrusterModel ()
 ~SpacecraftThrusterModel () override=default
 Configure the system.
link_nameName of the link that the thruster is attached to.
actuator_numberIndex of the element to be used from the actuators message for a joint.
duty_cycle_frequencyFrequency of the duty cycle signal in Hz.
max_thrustMaximum thrust force in Newtons, applied on the «on» phase of the duty cycle.
topicName of the topic where the commanded normalized thrust is published. Unit is <0, 1>, corresponding to the percentage of the duty cycle that the thruster is on. Default uses the models name.
sub_topic[optional] Name of the sub_topic to listen to actuator message on.
This plugin replicates the PWM thruster behavior in: Nakka, Yashwanth Kumar, et al. "A six degree-of-freedom spacecraft dynamics simulator for formation control research." 2018 AAS/AIAA Astrodynamics Specialist Conference. 2018. -> 'Thruster Firing Time' Phodapol, S. (2023). Predictive Controllers for Load Transportation in Microgravity Environments (Dissertation). -> '5.3.4 PWM Controller Node' Retrieved from https://urn.kb.se/resolve?urn=urn:nbn:se:kth:diva-344440
◆ SpacecraftThrusterModel()
◆ ~SpacecraftThrusterModel()
~SpacecraftThrusterModel ( )
overridedefault
