OdometryPublisher Class Reference
Odometry Publisher which can be attached to any entity in order to periodically publish 2D or 3D odometry data in the form of gz::msgs::Odometry messages. More...
#include <OdometryPublisher.hh>
 OdometryPublisher ()
 ~OdometryPublisher () override=default
 Configure the system.
  • <odom_frame>: Name of the world-fixed coordinate frame for the is {name_of_model}/odom.
  • <robot_base_frame>: Name of the coordinate frame rigidly attached to the mobile robot base. This element is optional, and the default value is {name_of_model}/base_footprint.
  • <odom_publish_frequency>: Odometry publication frequency. This element is optional, and the default value is 50Hz.
  • <odom_topic>: Custom topic on which this system will publish odometry messages. This element is optional, and the default value is /model/{name_of_model}/odometry.
  • <odom_covariance_topic>: Custom topic on which this system will publish odometry with covariance messages. This element is optional, and the default value is /model/{name_of_model}/odometry_with_covariance.
  • <tf_topic>: Custom topic on which this system will publish the transform from odom_frame to robot_base_frame. This element is optional, and the default value is /model/{name_of_model}/pose.
  • <dimensions>: Number of dimensions to represent odometry. Only 2 and 3 dimensional spaces are supported. This element is optional, and the default value is 2.
  • <xyz_offset>: Position offset relative to the body fixed frame, the default value is 0 0 0. This offset will be added to the odometry message.
  • <rpy_offset>: Rotation offset relative to the body fixed frame, the default value is 0 0 0. This offset will be added to the odometry message.
  • <xyz_global_offset>: Position offset of the odometry frame relative to the world frame, the default value is 0 0 0.
  • <rpy_global_offset>: Rotation offset of the odometry frame relative to the world frame, the default value is 0 0 0.
  • <gaussian_noise>: Standard deviation of the Gaussian noise to be added to pose and twist messages. This element is optional, and the default value is 0.
Components
This system uses the following components:
◆ OdometryPublisher()
◆ ~OdometryPublisher()
~OdometryPublisher ( )
overridedefault
◆ PostUpdate()
