CameraVideoRecorder Class Referencefinal
Record video from a camera sensor. More...
#include <gz/sim/systems/CameraVideoRecorder.hh>
 CameraVideoRecorder ()
 ~CameraVideoRecorder () final=default
 Documentation inherited.
  • <service>: Name of topic for the video recorder service. If this is not specified, the topic defaults to: /world/<world_name>/model/<model_name>/link/<link_name>/ sensor/<sensor_name>/record_video
  • <use_sim_time>: True/false value that specifies if the video should be recorded using simulation time or real time. The default is false, which indicates the use of real time.
  • <fps>: Video recorder frames per second. The default value is 25, and the support type is unsigned int.
  • <bitrate>: Video recorder bitrate (bps). The default value is 2070000 bps, and the supported type is unsigned int.
◆ CameraVideoRecorder()
◆ ~CameraVideoRecorder()
~CameraVideoRecorder ( )
finaldefault
finalvirtual
◆ PostUpdate()
finalvirtual
