Magnetometer Class Reference
An magnetometer sensor that reports the magnetic field in its current location. More...
#include <Magnetometer.hh>
 Magnetometer ()
 ~Magnetometer () override
 Configure the system.
 Documentation inherited.
◆ Magnetometer()
Magnetometer ( )
◆ ~Magnetometer()
~Magnetometer ( )
◆ PostUpdate()
finalvirtual
finalvirtual
