LensFlare Class Reference
Add lens flare effects to the camera output as a render pass. More...
#include <gz/sim/systems/LensFlare.hh>
 LensFlare ()
 ~LensFlare () override=default
 Document Inherited.
  • <scale>: Sets the scale of the lens flare. If this is not specified, the value defaults to 1.0
  • <color>: Sets the color of the lens flare. The default is {1.4, 1.2, 1.0}
  • <occlusion_steps>: Sets the number of steps to take in each direction to check for occlusions. The default value is set to 10. Use 0 to disable
  • <light_name>: Sets the light associated with the lens flares. If not specified. The first light in the scene will be used.
◆ LensFlare()
LensFlare ( )
◆ ~LensFlare()
~LensFlare ( )
overridedefault
Document Inherited.
