JointPositionController Class Reference
Joint position controller which can be attached to a model with a reference to a single joint. More...
#include <JointPositionController.hh>
 JointPositionController ()
 ~JointPositionController () override=default
 Configure the system.
void ConfigureParameters (gz::transport::parameters::ParametersRegistry &_registry, EntityComponentManager &_ecm) override
 Configure the parameters of the system.
- Public Member Functions inherited from ISystemConfigureParameters
virtual ~ISystemConfigureParameters ()=default
A new Gazebo Transport topic is created to send target joint positions. The default topic name is "/model/<model_name>/joint/<joint_name>/<joint_index>/cmd_pos".
This topic accepts gz::msgs::Double values representing the target position. If you wish to change the topic on which this plugin listens you may use the <topic> parameter to specify which topic the plugin should listen on.
  • <joint_name> The name of the joint to control. Required parameter. Can also include multiple <joint_name> for identical joints.
  • <joint_index> Axis of the joint to control. Optional parameter. The default value is 0.
  • <use_actuator_msg> True to enable the use of actuator message for position command. Relies on <actuator_number> for the index of the position actuator and defaults to topic "/actuators".
  • <actuator_number> used with <use_actuator_msg> to set the index of the position actuator.
  • <p_gain> The proportional gain of the PID. Optional parameter. The default value is 1.
  • <i_gain> The integral gain of the PID. Optional parameter. The default value is 0.1.
  • <d_gain> The derivative gain of the PID. Optional parameter. The default value is 0.01
  • <i_max> The integral upper limit of the PID. Optional parameter. The default value is 1.
  • <i_min> The integral lower limit of the PID. Optional parameter. The default value is -1.
  • <cmd_max> Output max value of the PID. Optional parameter. The default value is 1000.
  • <cmd_min> Output min value of the PID. Optional parameter. The default value is -1000.
  • <cmd_offset> Command offset (feed-forward) of the PID. Optional parameter. The default value is 0.
  • <use_velocity_commands> Bypasses the PID and creates a perfect position. The maximum speed on the joint can be set using the <cmd_max> tag.
  • <topic> If you wish to listen on a non-default topic you may specify it here, otherwise the controller defaults to listening on "/model/<model_name>/joint/<joint_name>/<joint_index>/cmd_pos".
  • <sub_topic> If you wish to listen on a sub_topic you may specify it here "/model/<model_name>/<sub_topic>".
  • <initial_position> Initial position of a joint. Optional parameter. The default value is 0.
◆ JointPositionController()
◆ ~JointPositionController()
~JointPositionController ( )
overridedefault
◆ ConfigureParameters()
void ConfigureParameters ( gz::transport::parameters::ParametersRegistry &  _registry,
[in]_registryThe parameter registry.
[in]_ecmThe entity component manager.
Implements ISystemConfigureParameters.
