DetachableJoint Class Reference
A system that initially attaches two models via a fixed joint and allows for the models to get detached during simulation via a topic. A model can be re-attached during simulation via a topic. The status of the detached state can be monitored via a topic as well. More...
#include <DetachableJoint.hh>
 DetachableJoint ()=default
 Documentation inherited.
  • <parent_link>: Name of the link in the parent model to be used in creating a fixed joint with a link in the child model.
  • <child_model>: Name of the model to which this model will be connected
  • <child_link>: Name of the link in the child model to be used in creating a fixed joint with a link in the parent model.
  • <initial_attach> (optional): If true, the joint starts attached when the system loads. If false, the joint starts detached (no initial joint is created until an attach request is received). Defaults to true to preserve backward compatibility.
  • <topic> (optional): Topic name to be used for detaching connections. Using <detach_topic> is preferred.
  • <detach_topic> (optional): Topic name to be used for detaching connections. If multiple detachable plugin is used in one model, detach_topic is REQUIRED to detach child models individually.
  • <attach_topic> (optional): Topic name to be used for attaching connections. If multiple detachable plugin is used in one model, attach_topic is REQUIRED to attach child models individually.
  • <output_topic> (optional): Topic name to be used for publishing the state of the detachment. If multiple detachable plugin is used in one model, output_topic is REQUIRED to publish child models state individually.
  • <suppress_child_warning> (optional): If true, the system will not print a warning message if a child model does not exist yet. Otherwise, a warning message is printed. Defaults to false.
◆ DetachableJoint()
DetachableJoint ( )
default
finalvirtual
finalvirtual
