FreeSpaceExplorer Class Reference
This plugin is to be used with a model that has a 2D LiDAR attached to it. It uses this 2d lidar to export an occupancy map of the world. More...
#include <FreeSpaceExplorer.hh>
 FreeSpaceExplorer ()
 ~FreeSpaceExplorer () override
 Documentation inherited.
This system takes in the following parameters:
  • <lidar_topic> - Topic to listen to LiDAR on
  • <width> - Number of columns in the occupancy map
  • <height> - Number of rows in the occupancy map
  • <resolution> - Resolution of an individual cell
  • <sensor_link> - Link on which the sensor is attached within the model.
  • <image_topic> - Topic to publish occupancy map on
  • <start_topic> - Topic to listen on before starting exploration.
Note: It is assumed the sensor does not implement any pose offset from the link itself. This may of may not be true. and should be fixed in a future release.
◆ FreeSpaceExplorer()
◆ ~FreeSpaceExplorer()
~FreeSpaceExplorer ( )
EventManager &
◆ PostUpdate()
