TouchPlugin Class Reference
Plugin which publishes a message if the model it is attached to has touched one or more specified targets continuously during a given time. More...
#include <TouchPlugin.hh>
 TouchPlugin ()
 ~TouchPlugin () override=default
 Configure the system.
 Documentation inherited.
- Public Member Functions inherited from ISystemReset
virtual ~ISystemReset ()=default
After publishing, the plugin is disabled. It can be re-enabled through a Gazebo Transport service call.
The plugin requires that a contact sensor is placed in at least one link on the model on which this plugin is attached.
  • <target> Name, or substring of a name, that identifies the target collision entity/entities. This value is searched in the scoped name of all collision entities, so it can possibly match more than one collision. For example, using the name of a model will match all of its collisions (scoped name /<model_name>/<link_name>/<collision_name>).
  • <collision> Optional parameter. Multiple <collision> elements are allowed. If specified, a touch event will only be emitted if contact occurs with the specified contact sensor collision in the model that the touch plugin is attached to. If no <collision> elements are specified, all contact sensor collisions are used.
  • <create_contact_sensor_for_collision> Optional parameter. If true, automatically create a contact sensor for the collision if the sensor does not exist already. This allows the TouchPlugin system to be used without explicitly defining contact sensors inside links in SDF. Default to false.
  • <namespace> Optional parameter. Namespace for transport topics and services. Defaults to <scoped_name>/touch. Note that if multiple touch plugins without a namespace are added to a model their topic / service will conflict. In this case, it is recommended to either specify the namespace or use nested models to have only one touch plugin per model.
    • /<namespace>/enable : Service used to enable and disable the plugin.
    • /<namespace>/touched : Topic where a message is published once the touch event occurs.
  • <time> Target time in seconds to maintain contact.
  • <enabled> Set this to true so the plugin works from the start and doesn't need to be enabled.
◆ TouchPlugin()
◆ ~TouchPlugin()
~TouchPlugin ( )
overridedefault
◆ PostUpdate()
finalvirtual
◆ Reset()
finalvirtual
Implements ISystemReset.
