#include <WebsocketServer.hh>
 WebsocketServer ()=default
virtual ~WebsocketServer ()
 Documentation inherited.
void OnConnect (int _socketId)
 Callback that is triggered when a new connection is established.
void OnDisconnect (int _socketId)
 Callback that is triggered when a connection ended.
void OnMessage (int _socketId, const std::string _msg)
 Handles incoming websocket messages.
void Run ()
bool UpdateMsgTypeSubscriptionCount (const std::string &_topic, int _socketId, bool _subscribe)
 Check and update subscription count for a message type. If a client has more subscriptions to a topic of a specified type than the subscription limit, this will block subscription. On the other hand, for an unsubscription operation, the count is decremented.
Public Attributes
std::map< int, std::unique_ptr< Connection > > connections
 All of the websocket connections.
int maxConnections {-1}
 The maximum number of connections. A negative number indicates no limit.
int messageCount {0}
 Number of pending messages. This is used to throttle the run loop.
std::map< std::string, int > msgTypeSubscriptionLimit
 The limit placed on the number of subscriptions per msg type for each connection. The key is the msg type, e.g. gz.msgs.Image, and the value is the subscription limit.
std::mutex mutex
int queueSizePerConnection {-1}
 The message queue size per connection. A negative number indicates no limit.
std::condition_variable runConditionVariable
 Run loop condition variable.
std::mutex runMutex
 Run loop mutex.
std::mutex subscriptionMutex
 A mutex used in the OnWebsocketSubscribedMessage function.
std::map< std::string, std::set< int > > topicConnections
 All of the subscribed Gazebo topics. The key is the topic name, and the value is the set of websocket connections that have subscribed to the topic.
A websocket server for gzweb
Plugin parameters
  • <publication_hz> : An integer that is the maximum publication hertz rate.
  • <port> : An integer that is websocket port.
  • <authorization_key> : A key used for authentication. If this is set, then a connection must provide the matching key using an "auth" call on the websocket. If the <admin_authorization_key> is set, then the connection can provide that key.
  • <admin_authorization_key> : An admin key used for authentication. If this is set, then a connection must provide the matching key using an "auth" call on the websocket. If the <authorization_key> is set, then the connection can provide that key.
  • <max_connections> : An integer that specifies the maximum number of active websocket connections. A value less than zero indicates an unlimited number, this is the default. A websocket client error code of 1008 along with a reason set to "max_connections" will be returned if a new connection is rejected due to the max connection threshold.
  • <ssl> : Element that contains SSL configuration. For testing purposes you can create self-signed SSL certificates. Run
    openssl req -x509 -nodes -days 365 -newkey rsa:2048 -keyout server.key \
    -out server.cert
    Use "localhost" for the "Common Name" question. If you are testing with a browser, first navigate to "https://localhost:`<port>`" and accept the self-signed certificate.
    • <cert_file>: Child element of <ssl> that contains the path to the SSL certificate file.
    • <private_key_file>: Child element of <ssl> that contains the path to SSL private key file.
Websocket Server Interface
The websocket server listens for incoming requests and sends messages based on the requests.
All messages on the websocket, incoming and outgoing, are structured in a frame that consists of four comma separated components:
  1. operation: string,
  2. topic_name: string,
  3. message_type: string, and
  4. payload: serialized data.
The operation component is mandatory and must be one of:
  1. "sub": Subscribe to the topic in the topic_name component,
  2. "pub": Publish a message from the Gazebo Transport topic in the topic_name component,
  3. "topics": Get the list of available topics,
  4. "topics-types": Get the list of available topics and their message types,
  5. "protos": Get a string containing all the protobuf definitions, and
  6. "particle_emitters": Get the list of particle emitters. definitions.
  7. "unsub": Unsubscribe from the topic in the topic_name component
  8. "asset": Get a file as a byte array from a running Gazebo server. Set the payload to the file URI that is being requested.
  9. "worlds": Get world info.
  10. "scene": Get scene info.
  11. "image": Subscribe to an image in the topic_name component.
  12. "throttle": Throttle a topic in the topic_name component by the rate in the payload component.
  13. "req": Request a service, passing in the optional request message. The payload should be a serialized protobuf message. The response payload holds the serialized protobuf response, if any.
The topic_name component is mandatory for the "sub", "pub", "unsub", and "req" operations. If present, it must be the name of a Gazebo Transport topic.
The message_type component is mandatory for the "pub" and "req" operations. If present it names the Gazebo Message type, such as "gz.msgs.Clock".
The payload component is mandatory for the "pub" and "req" operations. If present, it contains a serialized string of a Gazebo Message.
Example frames
  1. Get the list of topics: topics,,,
  2. Get the protobuf definitions: protos,,,
  3. Subscribe to the "/clock" topic: sub,/clock,,
  4. Websocket server publishing data on the "/clock" topic: pub,/clock,gz.msgs.Clock,<serialized_data>
Example usage
Websocket Server
  1. Add the following to the top of an SDF file to include the websocket server system when launching a world.
<plugin name="WebsocketServer"
filename="gz-sim-websocket-server-system">
<!-- Publication Hz -->
<publication_hz>30</publication_hz>
  1. Launch your SDF world file, e.g.
gz sim -v 4 -s websocket.sdf
  1. Connect gzweb to the websocket server for web visualization. An example is provided in examples/scripts/websocket_server
◆ WebsocketServer()
WebsocketServer ( )
default
◆ ~WebsocketServer()
virtual ~WebsocketServer ( )
finalvirtual
◆ OnConnect()
void OnConnect ( int  _socketId)
[in]_socketIdID of the socket.
◆ OnDisconnect()
void OnDisconnect ( int  _socketId)
◆ OnMessage()
void OnMessage ( int  _socketId,
[in]_socketIdId of the socket associated with the message.
[in]_msgThe incoming message.
◆ Run()
void Run ( )
◆ UpdateMsgTypeSubscriptionCount()
bool UpdateMsgTypeSubscriptionCount ( const std::string &  _topic,
int  _socketId,
bool  _subscribe
[in]_topicTopic to subscribe to or unsubscribe from
[in]_socketIdConnection socket id
[in]_subscribeTrue for subscribe operation, false for unsubscribe operation
True if the subscription count is incremented or decremented, and false to indicate the subscription limit has reached.
◆ connections
std::map<int, std::unique_ptr<Connection> > connections
◆ maxConnections
◆ messageCount
◆ msgTypeSubscriptionLimit
std::map<std::string, int> msgTypeSubscriptionLimit
◆ mutex
std::mutex mutex
◆ queueSizePerConnection
◆ runConditionVariable
◆ runMutex
std::mutex runMutex
Run loop mutex.
◆ subscriptionMutex
◆ topicConnections
std::map<std::string, std::set<int> > topicConnections
