LogRecord Class Reference
Log state recorder. More...
#include <gz/sim/systems/log/LogRecord.hh>
 LogRecord ()
 ~LogRecord () override
void Configure (const Entity &_id, const std::shared_ptr< const sdf::Element > &_sdf, EntityComponentManager &_ecm, EventManager &_eventMgr) final
 Configure the system.
 Documentation inherited.
Log state recorder.
◆ LogRecord()
LogRecord ( )
◆ ~LogRecord()
~LogRecord ( )
finalvirtual
◆ PostUpdate()
finalvirtual
finalvirtual
