gz::sim::systems::multicopter_control Namespace Reference
struct  EigenTwist
 Struct containing linear and angular velocities. More...
struct  FrameData
 Frame data of a link including its pose and linear velocity in world frame as well as its angular velocity in body frame. More...
class  LeeVelocityController
struct  LeeVelocityControllerParameters
 Data structure containing various parameters for the Lee velocity controller. More...
struct  NoiseParameters
 Noise parameters used when computing frame data. These are all assumed to be gaussian. More...
struct  Rotor
 A struct that holds various properties of a rotor. More...
struct  VehicleParameters
 A struct that holds properties of the vehicle such as mass, inertia and rotor configuration. Gravity is also included even though it's not a parameter unique to the vehicle. More...
using RotorConfiguration = std::vector< Rotor >
 A collection of Rotor objects.
Functions
std::optional< Eigen::Matrix4Xd > calculateAllocationMatrix (const RotorConfiguration &_rotorConfiguration)
 Create the matrix that maps rotor velocities to thrust and moments.
void createFrameDataComponents (EntityComponentManager &_ecm, const Entity &_link)
 Creates components necessary for obtaining the frame data of the given link.
std::optional< FrameData > getFrameData (const EntityComponentManager &_ecm, const Entity &_link, const NoiseParameters &_noise)
 Retrieves the frame data of the given link and applies noise.
RotorConfiguration loadRotorConfiguration (const EntityComponentManager &_ecm, const sdf::ElementPtr &_sdf, const Model &_model, const Entity &_comLink)
 Loads rotor configuration from SDF.
Eigen::Matrix3d skewMatrixFromVector (const Eigen::Vector3d &_vector)
 Creates a skew symmetric matrix (so(3)) from a vector. This is sometimes referred to as the hat map.
Eigen::Vector3d vectorFromSkewMatrix (const Eigen::Matrix3d &_skewMatrix)
 Creates a vector from a skew symmetric matrix(so3). This is sometimes referred to as the vee map or inverse hat map.
Typedef Documentation
◆ RotorConfiguration
Function Documentation
◆ calculateAllocationMatrix()
std::optional< Eigen::Matrix4Xd > calculateAllocationMatrix ( const RotorConfiguration &  _rotorConfiguration)
[in]_rotorConfigurationRotor configurations
nullopt if the rotor configuration results in uncontrollable system. Otherwise, returns the computed matrix.
◆ createFrameDataComponents()
void createFrameDataComponents ( EntityComponentManager &  _ecm,
const Entity &  _link
[in]_ecmMutable reference to the entity component manager
[in]_linkLink on which the components will be created.
◆ getFrameData()
std::optional< FrameData > getFrameData ( const EntityComponentManager &  _ecm,
const Entity &  _link,
const NoiseParameters &  _noise
[in]_ecmImutable reference to the entity component manager
[in]_noiseNoise parameters
◆ loadRotorConfiguration()
RotorConfiguration loadRotorConfiguration ( const EntityComponentManager &  _ecm,
const sdf::ElementPtr &  _sdf,
const Model &  _model,
const Entity &  _comLink
[in]_ecmImmutable reference to the entity component manager
[in]_sdfPointer to the SDF element of the system
[in]_modelModel to which the system is attached
[in]_comLinkLink associated with the center of mass.
◆ skewMatrixFromVector()
Eigen::Matrix3d skewMatrixFromVector ( const Eigen::Vector3d &  _vector)
inline
[in]_vectorany vector in R3
a skew symmetric matrix in so(3)
◆ vectorFromSkewMatrix()
Eigen::Vector3d vectorFromSkewMatrix ( const Eigen::Matrix3d &  _skewMatrix)
inline
[in]_skewMatrixany matrix in so(3)
a vector in R3
