Rotor Struct Reference
A struct that holds various properties of a rotor. More...
#include <Parameters.hh>
Public Attributes
double angle
 The angle formed on the xy plane by the vector going from the the center of mass to the rotor. The angle is measured from the +x axis of the body frame.
double armLength
 The length of the vector going from the center of mass to the rotor.
int direction
 Direction of rotation of the rotor. +1 is counterclockwise and -1 is clockwise.
double forceConstant
 A constant that multiplies with the square of the rotor's velocity to compute its thrust.
double momentConstant
 A constant the multiplies with the rotor's thrust to compute its moment.
◆ angle
double angle
◆ armLength
double armLength
◆ direction
int direction
◆ forceConstant
◆ momentConstant
