PosePublisher Class Reference
Pose publisher system. Attach to an entity to publish the transform of its child entities in the form of gz::msgs::Pose messages, or a single gz::msgs::Pose_V message if "use_pose_vector_msg" is true. More...
#include <PosePublisher.hh>
 PosePublisher ()
 ~PosePublisher () override=default
 Configure the system.
  • <publish_link_pose>: Set to true to publish link pose. This element is optional, and the default value is true.
  • <publish_visual_pose>: Set to true to publish visual pose. This element is optional, and the default value is false.
  • <publish_collision_pose>: Set to true to publish collision pose. This element is optional, and the default value is false.
  • <publish_sensor_pose>: Set to true to publish sensor pose. This element is optional, and the default value is false.
  • <publish_model_pose>: Set to true to publish model pose. This element is optional. If it is not set, it takes the value of <publish_nested_model_pose>.
  • <publish_nested_model_pose>: Set to true to publish nested model pose. The pose of the model that contains this system is also published unless <publish_model_pose> is set to false. This element is optional, and the default value is false.
  • <use_pose_vector_msg>: Set to true to publish a gz::msgs::Pose_V message instead of multiple gz::msgs::Pose messages. This element is optional, and the default value is false.
  • <update_frequency>: Frequency of pose publications in Hz. A frequency of zero or less publishes as fast as possible (i.e., at the rate of the simulation step). This element is optional, and the default value is -1.
  • <static_publisher>: Set to true to publish static poses on a "<scoped_entity_name>/pose_static" topic. This will cause only dynamic poses to be published on the "<scoped_entity_name>/pose" topic. This element is optional, and the default value is false.
  • <static_update_frequency>: Frequency of static pose publications in Hz. A frequency of zero or less publishes as fast as possible (i.e., at the rate of the simulation step). Only used when <static_publisher> is true. This element is optional. If it is not set, it takes the value of <update_frequency>.
  • <topic>: Set a custom topic instead of default value
◆ PosePublisher()
◆ ~PosePublisher()
~PosePublisher ( )
overridedefault
◆ PostUpdate()
